![]() | Home > Puma (Tdci) > 2.4 Puma Fuel Pump Relay Location |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17991 ![]() ![]() ![]() |
Yes, it's none of them! 2.4 has a mechanical pump!
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
\sqirt on\
There are two pumps, one for transfer an the high pressure pump itself ![]() \sqirt off\ |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
As said not on the 2.4 only on 2.2
That’s why the 2.4 is a ![]() Wanted, Forward Control Anything considered. |
This is true of TD5's and 2.2 Puma's but the 2.4 doesn't have a lift/transfer pump. |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
Thanks guys - appreciate your help
Sorry to contradict, but it has a suction pump that brings fuel through filter to the high pressure pump. The fuel pressure from the suction pump is levelled by the VCV. They are both in one housing! |
There is no electric pump on the 2.4, there is a single two-stage mechanical pump on the nearside front of the engine.
Sorry Deleted post.
Can’t be arsed ![]() Wanted, Forward Control Anything considered. |
^^^ I know what you mean, the OP asked about which relay, there isnt one. End of
Which is a mechanical pump not an electric one, so there's no relay for it. ![]() The 2.2 and Td5 both have an electric in tank lift pump, the 2.4 doesn't. |
