![]() | Home > Technical > 58 plate Defender with Dim Dip? |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
I thought the headlight levelling used to be an option but became standard in the 2011MY. Russell
2011MY 110 XS USW Black |
It came as standard on my 2009 XS spec.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18026 ![]() ![]() ![]() |
Our European masters ruled that it was illegal for the UK government to require that dim-dip was fitted (the UK had introduced legislation requiring the fitment of dip-dip and it was the law which was ruled illegal) but it is still permitted if you or the manufacturer want to.
Defenders which are "commercial" used to have dim dip and no levelling (for example my 2007 'County' spec DC did), whilst those which were not considered commercial (eg the XS models) had headlight levelling and no dim-dip. The good news if you have dim dip is that it is very easy to disable it if you wish, by unplugging the resistor pack located in the OS front wing (although it is quite hard to find). It is also possible albeit probably unnecessary to retrofit levelling motors since the wiring harness is the same whether or not you have them. The suspension on a 'commercial' Defender renders their fitment unnecessary however. |
Dim dip is fitted to comercials, h/l leveling on station wagons 2.4 90 XS
TZ7XGP Member Since: 09 Mar 2011 Location: Cheshire Posts: 37 ![]() ![]() ![]() |
Thank's for the reply's. I am going to use the redundant wiring that is in the harness for the headlight leveling and the dim dip circuit to fit Daylight Running Lights.
As the more mature drivers in my area seem to enjoy pullind out infront of my black Defender! Steve. |
