Home > Technical > 58 plate Defender with Dim Dip?
TZ7XGP
United Kingdom 2009 Defender 90 Puma 2.4 SW Santorini Black
I have a 58 plate defender with no headlight leveling control on the dash. The hole is covered by a factory fitted blanking plate. But it does have Dim Dip! Checked LR webb site. It shows all defenders having headlight leveling.
I thought our european friends said it was illegal for the UK to have Dim Dip and that is one of the reasons it stopped being fitted years ago. Anyone know why its not got leveling fitted. I thought it may be because it is classed as a Light Goods.
Steve.
Post #63693 14th Mar 2011 6:41pm
BigRuss
I thought the headlight levelling used to be an option but became standard in the 2011MY. Russell
2011MY 110 XS USW Black
Post #63695 14th Mar 2011 6:48pm
Lorryman100
It came as standard on my 2009 XS spec.
Post #63702 14th Mar 2011 7:14pm
Our European masters ruled that it was illegal for the UK government to require that dim-dip was fitted (the UK had introduced legislation requiring the fitment of dip-dip and it was the law which was ruled illegal) but it is still permitted if you or the manufacturer want to.
Defenders which are "commercial" used to have dim dip and no levelling (for example my 2007 'County' spec DC did), whilst those which were not considered commercial (eg the XS models) had headlight levelling and no dim-dip.
The good news if you have dim dip is that it is very easy to disable it if you wish, by unplugging the resistor pack located in the OS front wing (although it is quite hard to find).
It is also possible albeit probably unnecessary to retrofit levelling motors since the wiring harness is the same whether or not you have them. The suspension on a 'commercial' Defender renders their fitment unnecessary however.
Post #63781 15th Mar 2011 9:40am
Grockle
Dim dip is fitted to comercials, h/l leveling on station wagons 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63787 15th Mar 2011 10:56am
TZ7XGP
Dim Dip
Thank's for the reply's. I am going to use the redundant wiring that is in the harness for the headlight leveling and the dim dip circuit to fit Daylight Running Lights.
As the more mature drivers in my area seem to enjoy pullind out infront of my black Defender!
Steve.
Post #63794 15th Mar 2011 12:52pm
