![]() | Home > My Defender > here she is |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
The rear wings were looking rough around the edges , so cut them off . Tub is all but done too . Need to get it out of the garage for final line up and tighten . Few jobs I gonna look at in the future , move the rad to the rear , get a winch in the front but not sticking out by a mile , might even get a tube arse end too , but time will tell . One thing noticed , I have to remove me roof to get it into the garage , when I remove all excess weight , I can’t get it in at all , may look to going back to the series screen idea
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Cleaned up some parts and painted , have ordered some Ali brackets , once they arrive I’ll rebuild
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083 ![]() ![]() |
Loving that temp snorkel
![]() It's surprising what you can get done on your day off ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Cheers dude
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
From Sunday
Great pic's there and the 90 looking right at home
![]() The snorkel worked all okay i take it ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Here there , yep the snorkel worked perfectly , although I still don’t think a snorkel is required unless the lake is 4ft plus deep , you can see the air intake is clear because of the bow wave , the pic here is when the lake is deeper , snorkel is needed then
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
Yes i did notice the vent was visible but you just never know if there is a sudden hole
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
cheers fella , i sit and watch others
![]() ![]() a little more done on the new tank position , the td5 tank hanger brackets arrived and i modified to suit , a smidge of welding and shes spot on , a coat of gravitex and bobs your uncle , next up , re-wire and re-plumb the tank , then it rear bulkhead mod time ![]() Click image to enlarge ![]() Click image to enlarge |
Bye bye 8mm nuts n bolts and Penny washers and hello to a 10mm thick block of Ali and 10mm bolts , she’s a lot less floppy now , will repeat on the other side when I have turned her around
![]() Click image to enlarge ![]() Click image to enlarge The tank is in , lots of clearance , had to modify the cradle to get my D rings in , she’s plumbed in to , temp electrics fitted to bled and run to check for leaks , and guess what , no leaks , next up , drivers side rear wing ![]() Click image to enlarge ![]() Click image to enlarge |
Lots of small garage visits today , the drivers side of the tub is fitted and I spent a little time lining things up , behind the scenes are much stronger Ali brackets , bigger bolts and bigger rivets , so much stronger now , more odds n sods ordered , next up , do some wiring
Great work going on and with the tank, good result with no leaks
Have started on the other side at last
