Home > Maintenance & Modifications > Closed Cell Foam Under Bonnet?
bankz5152
Evening chaps,
Been doing some hefty soundproofing over the past week or so and got some 6mm closed cell foam left over, its not foil lined or anything just wondering if it would be alright to use under the bonnet?
Or could I stick some ali foil to the foam then use it?
Thanks
Josh.
Post #672525 21st Dec 2017 8:38pm
grafty99
I would get the bonnet specific stuff personally. In the summer and under big loads even a diesel can create some pretty high under bonnet temperatures.
Having said that, if you really want to use it then I would definately foil line it first Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #672527 21st Dec 2017 8:51pm
bankz5152
Yeah I see what you mean! Mainly just as I have some left over and being closed cell wont absorb water! Where as the proper under bonnet stuff is usually open cell which fills up with water and eventually sags and falls down
Got a layer of LizardSkin on it now so that should make a difference anyhow
Cheers Smile
Post #672528 21st Dec 2017 9:06pm
grafty99
Sealing around the edge of the bonnet makes quite a big difference as well. I did mine with 15mm × 15mm closed cell foam strip Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672530 21st Dec 2017 9:11pm
bankz5152
Not a bad shout that, think ive got some neoprene left over from making new bulkhead vents. Pretty big gap there too!
Post #672531 21st Dec 2017 9:16pm
grafty99
1990 Vogue SE
Post #672549 21st Dec 2017 10:16pm
zsd-puma
I think the foil covered stuff just cooks the engine plastics, as it just reflects all the heat back.
I've got some black under bonnet foam, basically a foam with a sort of perforated vinyl on it. It's lasted fine over the past year, and the adhesive is giving up a bit around the edges but it's not coming off enough to worry about.
I also put some foam strips along the sides and front of the bonnet so it seals against the wings and front panel, that makes a surprising difference to the noise and keeps most of the water and dirt out.
Post #672592 22nd Dec 2017 1:28am
bankz5152
Cut the foam, foil backed and glued in place with some high temp (200c) sprayglue! Currently being weighted down, ill get aome pics shortly Smile
Post #672633 22nd Dec 2017 12:48pm
bankz5152
All done! Quick and simple to do, did the edge of the bonnet as suggested, had just enough left over.
Preliminary results a tad quiter but it is alot more "dead" very few rattles and the like. Well worth it!
Post #672644 22nd Dec 2017 2:41pm
grafty99
Looking good, I need to do my bonnet again, it was all stripped off for the respray Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672655 22nd Dec 2017 3:47pm
bankz5152
Nice! Think if I ever got mine resprayed it would be with Buzzwelds super tough paint! Same colour of course i love my epsom green landy Very Happy
Post #672659 22nd Dec 2017 4:24pm
grafty99
I had everything done with buzzweld 2k chassis armour on the inside, definately helps to deaden the panels Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672662 22nd Dec 2017 4:31pm
bankz5152
Very nice indeed!!
Post #672666 22nd Dec 2017 4:45pm
