Home > Technical > Window Lift
Merlin
Window Lift
Please will someone post the diagram for a 2008 Puma wiring. My RH window has stopped working. I have checked the wiring in the door for failure and it's not that. I get battery on both wires, red and blue, which goes out when the switch is pressed.
Merlin
Post #672497 21st Dec 2017 6:07pm
dorsetsmith
Post #672499 21st Dec 2017 6:21pm
Merlin
Thank you.
Wonder why I would be getting battery on both wires
Post #672500 21st Dec 2017 6:23pm
grafty99
I'm not 100% sure but I think the diagram of the window switch isn't entirely accurate. I think both sides of the motor are held at battery voltage with ignition and then the appropriate wire is grounded to make the motor work. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #672501 21st Dec 2017 6:31pm
dorsetsmith
window switch swap (+ - ) over witch driver window motor CW or CCW and window mec up or down
Post #672506 21st Dec 2017 6:50pm
rallysteve
Standard defender switch gives +ve on both wires in the neutral position. The switch just pulls either wire to ground depending if you press up or down.
Post #672595 22nd Dec 2017 2:13am
Merlin
Thanks for the explanation, the switch diagram doesn't show that piece of important detail. Hence I must have a mechanical problem.
Merlin
Post #672608 22nd Dec 2017 9:19am
dorsetsmith
The switch diagram doesn't show that piece of important detail. Question
Whistle
Post #672613 22nd Dec 2017 9:44am
Merlin
What cuts out the motor when it gets to the full up/down position?
Merlin
Post #673059 24th Dec 2017 1:36pm
dorsetsmith
sound like motor , But
1. Id check all wire back to the fuse make shore all connector good ( as the voltage may be induct and when a load is applied going)
2.Can you test the motor with test leads from battery with 20 amp fuse in line Question
Post #673061 24th Dec 2017 1:48pm
Merlin
As the connector is so difficult to get to, does that mean I have to take out the motor and mechanism?
Post #673063 24th Dec 2017 2:20pm
dorsetsmith
try from this plug in A post
Post #673068 24th Dec 2017 2:49pm
Merlin
You do when you take your finger off the button on a Defender, otherwise nothing, the motor just stalls at either limit. Most vehicles sense either current draw or back-emf when the motor stalls and cut the power, but not the Defender.
Don't shut the window with a body part hanging out - it hurts!
Post #673135 24th Dec 2017 7:12pm
Merlin
I was hoping it was a simple fault. I have checked the electrical connections and the power is present where it should be when no in use and when the buttons are pressed. I can't hear the motor trying to work when I press the button. Any thoughts?
Merlin
Post #673146 24th Dec 2017 7:51pm
Merlin
Feel a bit silly now, it was a broken wire in the door jam. Thanks for everyone's help.
Merlin
Post #673468 26th Dec 2017 6:03pm
