![]() | Home > Technical > Window Lift |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Please will someone post the diagram for a 2008 Puma wiring. My RH window has stopped working. I have checked the wiring in the door for failure and it's not that. I get battery on both wires, red and blue, which goes out when the switch is pressed.
Merlin |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge |
Thank you.
Wonder why I would be getting battery on both wires |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
I'm not 100% sure but I think the diagram of the window switch isn't entirely accurate. I think both sides of the motor are held at battery voltage with ignition and then the appropriate wire is grounded to make the motor work.
window switch swap (+ - ) over witch driver window motor CW or CCW and window mec up or down
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Standard defender switch gives +ve on both wires in the neutral position. The switch just pulls either wire to ground depending if you press up or down.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks for the explanation, the switch diagram doesn't show that piece of important detail. Hence I must have a mechanical problem.
Merlin |
What cuts out the motor when it gets to the full up/down position?
Merlin |
sound like motor , But
1. Id check all wire back to the fuse make shore all connector good ( as the voltage may be induct and when a load is applied going) 2.Can you test the motor with test leads from battery with 20 amp fuse in line Last edited by dorsetsmith on 24th Dec 2017 2:23pm. Edited 1 time in total |
As the connector is so difficult to get to, does that mean I have to take out the motor and mechanism?
try from this plug in A post
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18037
You do when you take your finger off the button on a Defender, otherwise nothing, the motor just stalls at either limit. Most vehicles sense either current draw or back-emf when the motor stalls and cut the power, but not the Defender. Don't shut the window with a body part hanging out - it hurts! |
I was hoping it was a simple fault. I have checked the electrical connections and the power is present where it should be when no in use and when the buttons are pressed. I can't hear the motor trying to work when I press the button. Any thoughts?
Merlin |
Feel a bit silly now, it was a broken wire in the door jam. Thanks for everyone's help.
Merlin |
