Home > Td5 > TD5 Driver's Seat Mechanism
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
On the driver's seat of my 2004 TD5, the seat recliner mechanism ratchet has broken [I think a tooth has snapped off]; the mechanism was previously very stiff. Is it possible to replace the mechanism, or do I simply need to get a new seat back.
Thanks for any advice.
Post #671299 16th Dec 2017 9:04pm
4RF RDS
New seat frame likely needed. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #671305 16th Dec 2017 9:33pm
DieselBeast
1998 Defender 90 300 Tdi PU Java Black
You can strip them down and re-cut the teeth on the mechanism. But if you want a quick fix, new frame would do the trick
Post #671345 16th Dec 2017 11:37pm
mpald
Thank you both - much appreciated. Having failed with all the standard on-line retailers to get one, I got a new seat back from eBay for £42 + P & P. It will do but may consider replacing all the seats for something newer.
Post #672722 22nd Dec 2017 8:44pm
