Home > Td5 > TD5 Driver's Seat Mechanism
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
On the driver's seat of my 2004 TD5, the seat recliner mechanism ratchet has broken [I think a tooth has snapped off]; the mechanism was previously very stiff. Is it possible to replace the mechanism, or do I simply need to get a new seat back.
Thanks for any advice.
Post #671299 16th Dec 2017 8:04pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
New seat frame likely needed. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #671305 16th Dec 2017 8:33pm
DieselBeast
1998 Defender 90 300 Tdi PU Java Black
You can strip them down and re-cut the teeth on the mechanism. But if you want a quick fix, new frame would do the trick
Post #671345 16th Dec 2017 10:37pm
mpald
Thank you both - much appreciated. Having failed with all the standard on-line retailers to get one, I got a new seat back from eBay for £42 + P & P. It will do but may consider replacing all the seats for something newer.
Post #672722 22nd Dec 2017 7:44pm
