Home > Puma (Tdci) > Turbo temp fault
pkrynicki1984
United Kingdom 2007 Defender 110 Puma 2.4 HT Rioja Red
Turbo temp fault
Have seen similar threads.
When cruising on a run my turbo seems to stop boosting altogether.
seems to turn into a gutless old diesel , resetting the ignition cures it but it happens soon after.
Engine management light is on.
2007 2.4 tdci
Post #669281 6th Dec 2017 10:15am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
have you checked the air pipes for splits its a common fault
Post #669303 6th Dec 2017 1:16pm
pkrynicki1984
will do thanks.
seems strange that a reset sorts it out.
Post #669308 6th Dec 2017 2:40pm
dorsetsmith
Sound more like electric problem with turbo controls ( Actuator vane) VGT if you can reset by switching ignition off
and no high pitch air sound and lots of black smoke from exhaust Exclamation
plug the diagnostic in and read fault codes loge in ECM this will help you track down you problem
work shop Manuel below for 2.4 engine
https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7
Post #669309 6th Dec 2017 3:16pm
Chopperone
See my thread on temporary turbo failure.
I thought initially that my problem was a heat problem but I had no change in temp & no warning lights.
In your case I would remove the MAF sensor & wash it off - plenty of info on this site & see if that clears the problem.
Meanwhile I will be investigating my problem
Guy May your life be like toilet paper ; long & useful.
Post #669442 6th Dec 2017 11:42pm
pkrynicki1984
Thanks for that.
Post #669488 7th Dec 2017 9:14am
You might also want to check that the wiring harness that runs from the ECU all aruond and over the engine to the turbo actuator isn't chafing and getting damaged at any of the points of contact on the engine. My turbo ceased to boost because one of the feedback connections from the actuator stepper motor wore through because of this, widespread, problem. When I inspected the harness there was significant chafing damage at about four places, and at one point the insulation on the main (permanently live) feed from the alternator to the battery was chafed to the point you could just see copper. I reckon I was days away from a mojor vehicle fire.
After I repaired the broken wire and reinsulated the other damaged ones, then rewrapped the harness and secured it better with more protection, the turbo worked perfectly again. I do still check it for damage as part of my regular service checks.
Post #669491 7th Dec 2017 9:29am
pkrynicki1984
Many thanks for that.
I'll give it an inspection later , would it still make sense a ignition reset cures my problem ? usually for a very similar amount of time until the turbo dies again?
Post #669511 7th Dec 2017 11:36am
It is possible, if, for example, something is intermittently grounding and causing a fault, then un-grounding.
Post #669529 7th Dec 2017 1:31pm
