![]() | Home > Technical > Air intake on early defender |
Gas man Member Since: 29 Jun 2017 Location: East Yorkshire Posts: 33 ![]() ![]() ![]() |
Definitely no air intakes!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
When i have fitted 200s we have often tried the 2.5td Metal air filter.
With 300s for ease as engine sits further fwd we used def 300 filter boxes. I expect ther 300disco one would go where td5 goes near bulkhead? I would drop engine in with rad, wings on and see what fits best Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
redact this , had look at generator pic from old job this type air filler fitted to the Perkins engine horizontally over driver end i.e. over the fly wheel with control panel in front close fitted to it with this at least inlet to air box is up the top wing but in wrong place river or ford crossing, have seen in the past local farms 90 with same air box type but with short fex pipe work going back from the air box up to top of the inner wing and the air box had a drain at the bottom with one these fitted ![]() Last edited by dorsetsmith on 7th Nov 2017 10:32am. Edited 1 time in total |
Thanks all. I think the engine will sit exactly where he current 200tdi set up is, as I’m not changing the lt77 gearbox I currently have. I will keep options open though. Still some time off as this is the current state of the rebuild ![]() Click image to enlarge |
keep up good work
A surge of activity today, finished off spare “exchange”
![]() Click image to enlarge bulkhead ready for blasting prior to galvanising and also fitted towbar & fuel tank. |
steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 193 ![]() ![]() ![]() |
Would you consider fitting some sort of K&N filter under the bonnet to save replacement wings or cutting?
MineRover Member Since: 05 Apr 2015 Location: Essex Posts: 25 ![]() ![]() ![]() |
Hi,
In our early 110 I fitted a 300tdi and managed to find a tube that came out of the blanked off vent on the drivers side wing top and then adapted a through wing raised air intake to suit. To be honest I would rather not have a raised intake or a wing side intake but I believe you cannot run a 300tdi without one. ![]() Click image to enlarge |
