Home > Technical > MAP reading
vinsell
Italy 2008 Defender 90 Puma 2.4 SW Zermatt Silver
MAP reading
What is Your MAX MAP (manifold air pressure) reading? Mine (with scangauge) is 2,45 bar. I fitted itg air filter, Terrafirma silicone hoses, mantec snorkel (plastic jobby), BAS EGR blanking plate with 19 mm hole and racechip with position 9 and A.
Ciao Vinicio
Post #61636 1st Mar 2011 2:01pm
Lorryman100
I don't check the MAP pressure regularly but I remember getting about 34.9 psi (2.406 bar) at about 2300rpm with the engine under load. Checked it today and got readings up to 34 psi with the scangauge. Will check with the nanocom over the next week or so if you want me too?
Post #61833 2nd Mar 2011 6:02pm
MK
i`M NOT SURE WHAT UNITS ARE USED IN THE NNCOM.... Puma 110" SW
Post #61847 2nd Mar 2011 7:39pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Scangauge said following MAP:
14.3 idling after start
around 16-17 driving, without accelerating
above 20 when accelerating
It is with cold engine, about freezing outsde, Mantec snorkel installed, Puma 2007 without any ECU/ERG upgrades.
Does it say something for you?
Cheers! Janusz
www.yahodeville.com
Post #61926 3rd Mar 2011 8:07am
dgardel
Italy
Re: MAP reading
Ciao Vinicio
correct value
1,00bar mean atmospheric pressure for the ECU plus 1,45 bar of turbo boost Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #61950 3rd Mar 2011 10:27am
