![]() | Home > Technical > MAP reading |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 ![]() ![]() ![]() |
What is Your MAX MAP (manifold air pressure) reading? Mine (with scangauge) is 2,45 bar. I fitted itg air filter, Terrafirma silicone hoses, mantec snorkel (plastic jobby), BAS EGR blanking plate with 19 mm hole and racechip with position 9 and A.
Ciao Vinicio |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
i`M NOT SURE WHAT UNITS ARE USED IN THE NNCOM.... Puma 110" SW
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
Scangauge said following MAP:
14.3 idling after start around 16-17 driving, without accelerating above 20 when accelerating It is with cold engine, about freezing outsde, Mantec snorkel installed, Puma 2007 without any ECU/ERG upgrades. Does it say something for you? Cheers! Janusz www.yahodeville.com |
correct value 1,00bar mean atmospheric pressure for the ECU plus 1,45 bar of turbo boost Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
