Home > Maintenance & Modifications > Heater control valve
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Just a warning to give your heater valve a wiggle to make sure all is well!
My 08 Puma has just gone in to limp mode while driving, eventually coming to a stop!
The housing had cracked and come away loosing all its coolant Big Cry
Just off to get some tools to bodge back together and get it home.
Hope it's ok Neutral
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #657218 14th Oct 2017 9:01am
That valve really is one of the nastier features of the Puma! Cheap and tacky in terms of quailty, and obscenely expensive to replace.
Post #657224 14th Oct 2017 10:04am
ian series 1
Got one on order, at least it was a simple road side fix!
Your right, not the cheapest of parts for what it is.
Engine seems ok now, when I realised something was wrong, I pulled over to look under the Bonnet, and noticed it had dumped all its coolant, it was all very hot, and not at all happy!
I tried to restart it, and it was having none of it, it would hardly turn over,
I thought that was the end!
It all seems ok now it's cooled down, and replenished with coolant.
Good job I wasn't bowling down the motorway! 80" 80" 86" 88" 90"
Post #657233 14th Oct 2017 11:59am
Mo Murphy
Wouldn't happen in a series 1 😉
50 Shades of Pennine Grey
Post #657265 14th Oct 2017 6:00pm
ian series 1
Your not kidding!
Maybe I should just use one as a daily drive?
Be a lot less hassle! Wink 80" 80" 86" 88" 90"
Post #657273 14th Oct 2017 6:43pm
UtilityTruck
Is there a trusted aftermarket replacement?
That’ doesn’t look like a great design, clearly the heating+cooling effect plus normal vibration is fatiguing that joint. Fairly serious implications of it going too. 2014 Keswick Utility 2.2
Post #657283 14th Oct 2017 8:00pm
ian series 1
I don't think there is an uprated replacement?
I'm sure there has been a topic on this part not that long ago asking the same thing? 80" 80" 86" 88" 90"
Post #657289 14th Oct 2017 8:13pm
Perhaps a solution would be to engineer some sort of nearby support for the two pipes so they're not hanging on the valve body? Darren
Post #657341 15th Oct 2017 7:49am
dorsetsmith
also make shore pipe work to control valve has free movement, as works 09 Heater control valve failed three time repaired by LRJ, last time it failed repaired it my self and replace pipe work as it work harden with heat also slightly longer to give free movement
Post #657573 16th Oct 2017 1:05pm
