![]() | Home > Maintenance & Modifications > Heater control valve |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17859 ![]() ![]() ![]() |
That valve really is one of the nastier features of the Puma! Cheap and tacky in terms of quailty, and obscenely expensive to replace.
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Got one on order, at least it was a simple road side fix!
Your right, not the cheapest of parts for what it is. Engine seems ok now, when I realised something was wrong, I pulled over to look under the Bonnet, and noticed it had dumped all its coolant, it was all very hot, and not at all happy! I tried to restart it, and it was having none of it, it would hardly turn over, I thought that was the end! It all seems ok now it's cooled down, and replenished with coolant. Good job I wasn't bowling down the motorway! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2360 ![]() ![]() ![]() |
Wouldn't happen in a series 1 😉
Your not kidding!
Maybe I should just use one as a daily drive? Be a lot less hassle! ![]() Wanted, Forward Control Anything considered. |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
Is there a trusted aftermarket replacement?
That’ doesn’t look like a great design, clearly the heating+cooling effect plus normal vibration is fatiguing that joint. Fairly serious implications of it going too. 2014 Keswick Utility 2.2 |
I don't think there is an uprated replacement?
I'm sure there has been a topic on this part not that long ago asking the same thing? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Perhaps a solution would be to engineer some sort of nearby support for the two pipes so they're not hanging on the valve body? Darren
also make shore pipe work to control valve has free movement, as works 09 Heater control valve failed three time repaired by LRJ, last time it failed repaired it my self and replace pipe work as it work harden with heat also slightly longer to give free movement
