![]() | Home > Maintenance & Modifications > Sound Insulation- Dashboard |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893 ![]() ![]() ![]() |
Morning all.
Looking to tackle the sound Insulation on my DC in the next week or so. As mentioned on another thread, I've already tackled a SW but I want to make my DC as comprehensive a fit as possible. With this in mind I'm thinking about the Dash and whether to tackle behind it? FYI it's a MY2011 2.4. I've taken a look at photos on line, (OT, seem to be loads of Puma dashes for sale, suspicious?), which has led to a number of questions: 1. how hard is the dash to remove 2. I've noticed in the photos that there's already a patch of felt Insulation in place, similar material to that used on the transmission tunnel. Given I think I'm right in saying the transmission tunnel Insulation was either only available with the comfort pack and/or on the 2.2, does anyone who has a 2.4 know if the felt is in place on theirs? 3. How accessible is the bulkhead once the Dash is removed, with regards to applying some sound deadener and Insulation? Obviously quite a bit of sound comes from this area, so if it's not too fiddly or technical (labourious I'm ok with) and a useful amount of insulation can be added, then I'd be inclined to make the effort. Thanks in advance ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Had a few on my phone!
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Given the mass of the dashboard itself, I'm not sure how much you'd gain by insulating behind it. Doing the footwells up underneath the dash and the gearbox tunnel will give you a lot more benefit for the effort involved. Darren
Your probably right, not much to gain!
Footwells and tunnel would be my priority too. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
Thank you both. If there's little reason, I wouldn't bother, I know I'll only make a pigs ear getting it put back together. Will be putting lashings of the stuff in the footwells, transmission etc.
![]() However, on a similar note I am replacing my tweeters and speakers, and ideally cabling too, would that require the dash to come off or at least be pulled forward as in Ian's photos? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5132 ![]() ![]() ![]() |
Or you could buy a lead lined self-adhesive blanket from Noisekiller for the engine bulkhead best soundproofing option you can get.
You do not need to remove much just cut it into strips and cut out the profiles. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Thanks Gilarion, will look it up as I didn't know there was such a thing.
Think Exmoor trim do the lead lined bulkhead blankets,
Or they did once upon a time?.... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1488 ![]() ![]() ![]() |
I can't see any reason to take the dash out to replace speakers, tweeters or wiring.
Removing the radio should give enough access at the top end for wiring. At the lower side of the dash there is access through the fusebox covers and speaker holes, once the speakers are out.[/quote] |
Tweeters just pop out too, no fixings as such.
Plenty of room to feed wires in and out of various holes etc ![]() Wanted, Forward Control Anything considered. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
I thought about doing behind the dash too but quickly realised as suggested it wasn't worthwhile.
I would recommend (which I have done myself too.) - Doing the gearbox tunnel, full floor pans and seatboxes. And seat box interior bases. There is a tangible gain to be achieved. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thank you all. Advice duly noted, will let you know how it goes. Am planning to do a (not entirely scientific) test for pre/post dB levels, just using an App.
Was lucky enough to discover last night, by pure chance given recent postings, that a mate here in Cham (who used to be a DJ/sound engineer and who is obsessed by music), also loves Defs. He's going to spend a weekend with me fitting the Focals and maximising their effectiveness. Given the DC has no rear speakers (or ports), we'll be making a speaker box to fit under the bench seat which will accommodate the 10", Sub and Amp. Result!! Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
For your footwells and Tunnel- the Wright-Offroad kit is the way to go- IMHO this is the stuff that they should have left the factory with.
Chris |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
^^^^^ what Chris said.. I have it in mine and saved the silent coat for inside the doors and places you can't see... 1993 200Tdi Defender 90
