Home > Puma (Tdci) > `Quality of fuel
Page 2 of 3 <123>
Rashers
Forgot to say, nice write up gilarion Thumbs Up
Much appreciated Bow down
Post #651603 20th Sep 2017 7:56pm
Retroanaconda
I tend to choose filling station based on when I need to fill up rather than brand. All I can say for sure is that I've never noticed a difference.
And in the past 116,000 miles of recorded driving the best performing (MPG) fuel type that's statistically significant is Tesco:
Post #651622 20th Sep 2017 8:38pm
Rashers
Very impressive, Retroanaconda Thumbs Up
I used to do that kind of thing (but in Excel format) for my company cars (I claimed a rate per mile and as long as there was a difference between what I got paid and how much the car cost to run per mile, I had won)
It was a few years back, but I seem to remember with a euro box, the way that I drove made a shed load more difference than where I filled up. As I said in a previous post, my fill ups were mostly Sainsbury's, sometimes Asda and sometimes Tesco mainly because of price per litre, and location of filling station.
My mate drove a four axel Daf tipper. The company he worked for had so many diesel thefts that they removed the tanks and gave the drivers agency cards. For a good while, they all squeezed the truck into Tesco's and pocketed the Tesco's Clubcard points. Very profitable. It didn't last forever and in the end they refused to take the Clubcards.
Post #651626 20th Sep 2017 8:50pm
JWL
I nearly allways fill from my local Sainsburys mainly due to cost and convenience. I've pretty much bought most of the diesel from the same place for the past 8 years and just over 100K miles. I'm sure that if I spent more on a premium fuel on a named forecourt then I might get an odd mile or two per gallon but with mud tyres, permanent weight and more often than not short journeys I don't think it would really be noticable.
It was interesting to note that the old girl managed over 28mpg trundling to Peterborough and back dragging my Sankey loaded with all the stuff required when camping with a group, gazebo, firepit etc etc.
One thing that I believe that is in my favour is that there is a huge turnover of fuel sold through the particular Sainsburys so the fuel is allways fresh. A couple of years ago after a run of easily 7 months of using the same pump I called into another breed of supermarket forecourt, put £40 in of their standard fuel and 6 miles down the road I began to get fuelling problems. Got home and pulled the pump out of the tank of my Td5 and what was dripping off the pump resembled thin sump oil! It was black and was very "gloopy". I had a troublesome couple of days getting it through the pump and vowed never to use that particular garage again!
What I'm trying to say is that yes, our Defenders will run on supermarket fuels it's your own choice on what you want to pay.
Post #651643 20th Sep 2017 9:36pm
Swine&Small
arran jones wrote:
Use for all diesels Thumbs Up
Millers Oils Diesel Power Ecomax fuel treatment - 500ml buy from opie oils and in the discount code box when u check out...put in Def2 and u get a good discount Thumbs Up
Thanks Thumbs Up 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #651649 20th Sep 2017 9:45pm
Swine&Small
custom90steve wrote:
Yes - keeps things clean too and can be used permanently.
I have done for over two years now.
http://www.opieoils.co.uk/p-60222-millers-...tment.aspx
There is an Opie oils discount for members here which is 'DEF2'.
Once you use it you won't go back.
2012 VW T5 Camper
Post #651650 20th Sep 2017 9:46pm
Swine&Small
Retroanaconda... That is interesting Thumbs Up 1983 Series 3 Pick up in Marine Blue
2012 VW T5 Camper
Post #651652 20th Sep 2017 9:49pm
miker
Over the last 5 years I've done 70k in a vag diesel, 20k in the td5 defender, and about 10k in my van with the ford 2.2 engine.
Fuel is sourced from wherever is convenient and or cheap, supermarket and BP/shell, and I can't say I've ever noticed a difference! Also never found any nastiness in fuel filters to support issues with any fuel.
Post #651658 20th Sep 2017 10:15pm
MartinK
You may also consider the "Social Impact". Supermarkets are great at trashing family businesses (i.e. emptying the high street).
In my Dad's village, an Asda opened. As usual it killed a couple of smaller shops...
However after a few years, they opened a pharmacy. The pharmacy which had been there longer than anyone remembers (family business) went bust, jobs lost. Asda realized the profits were not as big as they would like. They closed the Asda pharmacy. Now the village has no Pharmacy at all.
B@stards.
The coin you spend is more important than the vote you cast for central govt sometimes... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #651713 21st Sep 2017 9:56am
"The coin you spend is more important than the vote you cast for central govt sometimes..."
Very true, removal of funds from what you don't like or believe in had the biggest effect. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #651756 21st Sep 2017 12:06pm
gilarion
You can indeed buy larger amounts but you would have to clock up plenty of miles per year to use it and keep it fresh.
You also then have to deal with transferring it with dosage.
How are you dealing with dosage volume Gilarion? Very Happy
I'm assuming transferring to a smaller dosing bottle or some other method?
Thumbs Up
I have a 500ML bottle that I fill from the can, though its a pig to fill. For me a Large can works as I have a Narrow Boat as well as two Defenders. The Narrow Boat eats diesel especially if I run the engine at night for heat and electric, the Leisure batteries do not last that long particularly if we are using the boat in the winter. Fortunately I am allowed to use Red diesel in the boat. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #651797 21st Sep 2017 1:39pm
Laurie
86,000 miles in 12 years on whatever's cheapest.
No ill effects so far.
Post #651801 21st Sep 2017 1:48pm
zsd-puma
There are Millions of Transits and Mondeos running around on what ever old diesel the driver could find with little or no ill effects.
I personally buy branded fuel, i used to run my mini on Tesco Petrol, but i was suffering from the engine stalling as to came to a stop, filled up at a branded station once and the stalling hasn't happened since, and a very noticable improvement in performance. I didn't think much of it at the time as it was just a filling station en route, but i certainly noticed a performance improvement, which made me give it more thought as to why - the change in fuel was the only variable.
There's nothing really wrong with Supermarket fuel for the most part, it exceeds the minimum standards, although it's likely the oil companies save their latest additive packages for their own fuel. The thing is though supermarket fuel isn't normally cheaper, as all the filling stations do price matching to within a given radius (normally 3 miles). So if you have a Shell, BP or Esso filling station within 3 miles of a Supermarket, the fuel will be the same price anyway. Sometimes you'll find a particular car will run better on say BP than Esso or vice versa.
It's the additive package that makes the difference, as the basic fuel all comes from the same tanks and pipes at the depot/refinery. The additives are added when the fuel is loaded into the road tanker.
Post #651816 21st Sep 2017 2:37pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I've had a bad tank of diesel before, ironically it was from Shell and it was their premium line. My Td5 ran rough and didn't start well.
Normally I run my diesels on Morrisons fuel as its litterally a stones throw from my place of work, I use forte products to maintain the fueling system. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #651822 21st Sep 2017 3:17pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
There is variability in the base fuel, they all will meet the BSEN standards etc but all standards have tolerances (i.e. Every criteria has a range), diesel (gas oil) can be from atmospheric or vacuum distillation of crude oil or from a cracked feed stock. Diesel and kerosene specs overlap and depending upon demand for Jet A1 (holiday season) the amount of Kero in diesel can vary. There are differences in blends between winter and summer. And most importantly the amount of bio diesel blended in and the type of bio diesel varies significantly, the bio addition is done at the road loading terminal and is specific to individual customer specification (significant tax implications).
And yes then the additives, detergents, anti waxing .... etc vary
Then the driving style of the driver varies, traffic varies, load being carried varies, tyres vary ..... 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #651840 21st Sep 2017 4:07pm
Page 2 of 3 <123>
