Home > Maintenance & Modifications > Winch/ Non-winch A-bars
Page 2 of 2 <12
SJM
"Winch" "bra" Snigger
(I'll get my coat) Simon
'11 Defender 110XS Utility SW
'07 Discovery 3 HSE
'58 Porsche 356A (not good off road)
'59 Lambretta (not good on or off road!)
Post #60929 24th Feb 2011 5:31pm
ashfordsv
Ireland 2006 Defender 90 Td5 SW Java Black
Thanks for that , i might give Goodwinch a ring! Thumbs Up
Post #60956 24th Feb 2011 7:23pm
BigMike
Good luck Laughing
Post #60961 24th Feb 2011 7:49pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Thanks for that last pic. Id wondered what the SVX front looked like with that A bar.
Pete
Post #60992 24th Feb 2011 10:59pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
ashfordsv wrote:
I have the non winch type bar with spots and was wondering if there is any way of shoehorning a winch under it?
Confused
I recently had a winch bumper made to my design. It looks the same as a standard defender bumper, but is made entirely from 6mm steel. It mounts to the chassis legs in the usual place, as well as mounting to the chassis crossmember ( just beneath radiator) I have a Warn 9.5 xp fitted. It required me to cut out the pressedsteel grill surround, but not the plastic grill. Sits 20mm further forward than standard bumper. Allows the original Poly A-bar to be fitted. Includes steel mounting spacer instead of the the thin cheap looking bracket that currently hold the A-bar on. Also comes with replacement 4mm steel brackets for the upper mountings ( just under the bonnet)
This bumper is tough as nails, looks almost exactly the same as factory one and even accomodates the original bumper end caps.
I don't have any photos just now, but I'm taking a load of photos once my roll cage is fitted this weekend. I'll try to post some up.
PM me if you're interested
They're only made when required, so there is a delay in manufacturing.
Post #62110 3rd Mar 2011 9:40pm
BigMike
I'd definitely be interested in seeing that mike
Post #62119 3rd Mar 2011 10:04pm
Page 2 of 2 <12
