Home > Maintenance & Modifications > Winch/ Non-winch A-bars |
ashfordsv Member Since: 13 Mar 2009 Location: Wicklow Posts: 82 |
Thanks for that , i might give Goodwinch a ring!
24th Feb 2011 7:23pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Good luck
24th Feb 2011 7:49pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Thanks for that last pic. Id wondered what the SVX front looked like with that A bar.
Pete |
24th Feb 2011 10:59pm |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
I recently had a winch bumper made to my design. It looks the same as a standard defender bumper, but is made entirely from 6mm steel. It mounts to the chassis legs in the usual place, as well as mounting to the chassis crossmember ( just beneath radiator) I have a Warn 9.5 xp fitted. It required me to cut out the pressedsteel grill surround, but not the plastic grill. Sits 20mm further forward than standard bumper. Allows the original Poly A-bar to be fitted. Includes steel mounting spacer instead of the the thin cheap looking bracket that currently hold the A-bar on. Also comes with replacement 4mm steel brackets for the upper mountings ( just under the bonnet) This bumper is tough as nails, looks almost exactly the same as factory one and even accomodates the original bumper end caps. I don't have any photos just now, but I'm taking a load of photos once my roll cage is fitted this weekend. I'll try to post some up. PM me if you're interested They're only made when required, so there is a delay in manufacturing. |
3rd Mar 2011 9:40pm |
I'd definitely be interested in seeing that mike
3rd Mar 2011 10:04pm |
