Home > Td5 > Loss of power and then White smoke
boode
England 2003 Defender 90 Td5 HT Rutland Red
Drove 5 miles this morning - all normal
Drove back and my 90 would not rev above 2000
No power to pull up the last hill - had to resort to low range and just got home
Felt live out was hitting a rev limiter at 2000
Cleaned the air filter - dusty but not too bad
It will now rev to 3000 but with more accelerator I get no more revs but clouds of White smoke
No smoke below the 3000
Any ideas ?
Post #643445 12th Aug 2017 2:04pm
boode
I have just checked the Red plug into the ECU and it has oil in it Sad
Post #643451 12th Aug 2017 3:13pm
mk1collector
At least it should be an easy fix. Ray
My build thread
Post #643475 12th Aug 2017 5:30pm
boode
So will it need a new ECU, and a new loom ?
Post #643477 12th Aug 2017 5:33pm
mk1collector
Hopefully not. Get some electrical contact cleaner and thoroughly clean the ecu terminals and red plug. Replace the loom with an oem or genuine one for about £40 then clean the plug out again weekly for the next two or three weeks and everything should be back to normal. Ray
My build thread
Post #643478 12th Aug 2017 5:41pm
dorsetsmith
try can of brake cleaner to start with to clean oil from the red plug and socket, order replacement injector loom fit it and keep cleaning oil from the plugs with luck your problem will be sorted
Post #643479 12th Aug 2017 5:42pm
boode
Thank you both for the helpful replies
Post #643529 12th Aug 2017 10:15pm
boode
I have cleaned the plug and replaced the injector harness
No difference - it will only rev to 2000 then lots of white smoke but no power
Should this be an instant fix ?
Post #643879 14th Aug 2017 4:11pm
srod
I can't comment if oil in the loom is the cause of your problem, however if you are going down this route then I would also consider opening up the ECU itself and seeing if there is any oil inside, to be done carefully in a clean and dry environment, and if so, rinse it out with some electronic pcb cleaner.
Post #643883 14th Aug 2017 4:22pm
mk1collector
Try unplugging the maf and having a drive and see if there is a difference. Ray
My build thread
Post #643886 14th Aug 2017 4:27pm
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
Does this not sound more like a intercooler hose problem?
Post #643887 14th Aug 2017 4:37pm
bankz5152
Boost hose/IC problem should result in black smoke - not enough air to fuel ratio
White smoke could mean your turbo is on way out. Pull the turbo induction hose off and wiggle the turbine around shouldnt have much play, up and down is ok but in and out means its failing.
Also check the lower turbo hose for excess oil, a little is ok a lot is bad.
Post #643891 14th Aug 2017 4:48pm
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
Might be a precursor to this:-
http://www.defender2.net/forum/topic55754.html Sad
Hope you find a fix that doesn't cost a fortune Thumbs Up
Post #643896 14th Aug 2017 5:14pm
Rich1968
Mine did this but only from cold, it was the MAF.
Rich
Post #643899 14th Aug 2017 5:50pm
MadTom
The oil is not a real problem, real problem are tiny connector on the injectors itself. And this is why LR recommends replacement of the injectors loom.
Try to look for some diagnostic (like nanocom) and log some data from test drive with the problem. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #643928 14th Aug 2017 6:55pm
