![]() | Home > Td5 > Loss of power and then White smoke |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 436 ![]() ![]() ![]() |
I have just checked the Red plug into the ECU and it has oil in it
At least it should be an easy fix. Ray
So will it need a new ECU, and a new loom ?
Hopefully not. Get some electrical contact cleaner and thoroughly clean the ecu terminals and red plug. Replace the loom with an oem or genuine one for about £40 then clean the plug out again weekly for the next two or three weeks and everything should be back to normal. Ray
try can of brake cleaner to start with to clean oil from the red plug and socket, order replacement injector loom fit it and keep cleaning oil from the plugs with luck your problem will be sorted
Thank you both for the helpful replies
I have cleaned the plug and replaced the injector harness
No difference - it will only rev to 2000 then lots of white smoke but no power Should this be an instant fix ? |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
I can't comment if oil in the loom is the cause of your problem, however if you are going down this route then I would also consider opening up the ECU itself and seeing if there is any oil inside, to be done carefully in a clean and dry environment, and if so, rinse it out with some electronic pcb cleaner.
Try unplugging the maf and having a drive and see if there is a difference. Ray
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 ![]() ![]() |
Does this not sound more like a intercooler hose problem?
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
Boost hose/IC problem should result in black smoke - not enough air to fuel ratio
White smoke could mean your turbo is on way out. Pull the turbo induction hose off and wiggle the turbine around shouldnt have much play, up and down is ok but in and out means its failing. Also check the lower turbo hose for excess oil, a little is ok a lot is bad. |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 ![]() ![]() ![]() |
Might be a precursor to this:-
http://www.defender2.net/forum/topic55754.html ![]() Hope you find a fix that doesn't cost a fortune ![]() |
Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 86 ![]() ![]() |
Mine did this but only from cold, it was the MAF.
Rich |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
The oil is not a real problem, real problem are tiny connector on the injectors itself. And this is why LR recommends replacement of the injectors loom.
Try to look for some diagnostic (like nanocom) and log some data from test drive with the problem. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
