Home > Tdi > Installing Power Steering '87 Ninety
Lund
United Kingdom 2003 Defender 90 Td5 PU Caledonian Blue
Good Evening,
I'm hoping that someone is able to help shed some light on this situation. I'm currently helping a friend to convert his 1987 90 to power steering. It has a later tdi engine fitted (out of a Discovery I presume). However the engine is without power steering and has a single v-ribbed belt/pulley.
Has anyone done a similar conversion and if so, do you know of a complete list of parts necessary to complete the job.
Here's what I think we'll need;
ANR2157G PUMP POWER STEERING
ERR3733 PULLEY - POWER STEERING
ERR2228 BRACKET - PUMP SUPPORT
ERR3287 DRIVE BELT
ANR2485 HOSE-SUCTION
QEH102460 PIPE
ANR2135 POWER STEERING HOSES
QFX000030 RESERVOIR ASSY
Thanks in advance.
Post #640195 27th Jul 2017 9:25pm
seriesonenut
I did this conversion many years ago to an 89 90 2.5 petrol. I went to a breaker who supplied all of the parts removed from a donor vehicle so cant help with part numbers. It is a spanner job, took about a day and was working no faults when I sold it a few years back. Good luck.
Post #640201 27th Jul 2017 9:53pm
Dobby
Don't forget the actual steering box. The 4 bolt is likely the easiest to find, and should be a straight swap,for the non ps 4 bolt that's there now, hopefully. Might need a compatible drop arm too. Depending on the box source engine.
You'll need a double, or even triple bottom pulley. Triple in case the middle groove doesn't line up with the pump.
Post #640209 27th Jul 2017 10:56pm
Lund
Thanks for your feedback guys. Ahh, good point. I'll check out the steering box and see what we've got to work with.
Post #640369 28th Jul 2017 6:00pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
I have a discovery 1 I'm scrapping with all the parts you need !
Let me know if your interested in buying them .
Regards
Foxy
Post #640563 29th Jul 2017 6:43pm
Dobby
Foxy. If Lund doesn't want them, I'd be interested.
Post #640580 29th Jul 2017 9:05pm
foxyred
Sorry Laptop has been down ! could see but not reply.
Dobby if you want the bits let me know as Lund has not messaged
Post #641680 3rd Aug 2017 6:56pm
