![]() | Home > Tdi > Installing Power Steering '87 Ninety |
| seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1249
I did this conversion many years ago to an 89 90 2.5 petrol. I went to a breaker who supplied all of the parts removed from a donor vehicle so cant help with part numbers. It is a spanner job, took about a day and was working no faults when I sold it a few years back. Good luck.
| Dobby Member Since: 23 May 2012 Location: East Seaxe Posts: 187 |
Don't forget the actual steering box. The 4 bolt is likely the easiest to find, and should be a straight swap,for the non ps 4 bolt that's there now, hopefully. Might need a compatible drop arm too. Depending on the box source engine.
You'll need a double, or even triple bottom pulley. Triple in case the middle groove doesn't line up with the pump. |
| Lund Member Since: 04 Jul 2016 Location: United Kingdom Posts: 49
Thanks for your feedback guys. Ahh, good point. I'll check out the steering box and see what we've got to work with.
Cheers |
| foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227
I have a discovery 1 I'm scrapping with all the parts you need !
Let me know if your interested in buying them . Regards Foxy |
Foxy. If Lund doesn't want them, I'd be interested.
Sorry Laptop has been down ! could see but not reply.
Dobby if you want the bits let me know as Lund has not messaged |
