![]() | Home > Technical > Clunking noise when changing gear on a Puma? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
drive flanges at the wheels
gearbox > transfer box intermediate shaft Rear axle top suspension link ball joint Good luck! |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
Hello, some of the people her explain to me the gear change clunk. It is slack somewhere. For me I change the A ball joint and fulcrum and after is gone.
If the UJ's are bad you can just get under the car and twist them with your hand, if they have excessive play you'll feel it. Grease the UJ's if it stops the clanking (probably temporarily) then it's probably UJ's
However it could be a failing clutch plate, adaptor shaft wear (between the gearbox and transfer box), drive flange wear or a combination of all of them. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
All the above, or gearbox ... or transfer box ... or diff ... or any combinatio of the above.
In fact, wear and slop just about anywhere in the drive line will give rise to this symptom. As a first step, check fort the Puma clutch death rattle (many threads on here tell how). |
