Home > Technical > Clunking noise when changing gear on a Puma?
JC80
United Kingdom 2013 Defender 110 Puma 2.4 USW Santorini Black
Hi all,
I recently purchased a 110 62 plate and when I change gear from 2nd to 3rd onwards when I release the clutch there is a loud clunking noise? It doesn't happen when I change from 1st to 2nd.
Do you think it could the UJ's?
Any help appreciated appreciated.
Thanks.
Post #632100 18th Jun 2017 7:10pm
ickle
drive flanges at the wheels
gearbox > transfer box intermediate shaft
Rear axle top suspension link ball joint
Good luck!
Post #632104 18th Jun 2017 7:35pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
Hello, some of the people her explain to me the gear change clunk. It is slack somewhere. For me I change the A ball joint and fulcrum and after is gone.
Post #632120 18th Jun 2017 8:33pm
zsd-puma
If the UJ's are bad you can just get under the car and twist them with your hand, if they have excessive play you'll feel it. Grease the UJ's if it stops the clanking (probably temporarily) then it's probably UJ's
However it could be a failing clutch plate, adaptor shaft wear (between the gearbox and transfer box), drive flange wear or a combination of all of them.
Post #632170 19th Jun 2017 6:11am
All the above, or gearbox ... or transfer box ... or diff ... or any combinatio of the above.
In fact, wear and slop just about anywhere in the drive line will give rise to this symptom.
As a first step, check fort the Puma clutch death rattle (many threads on here tell how).
Post #632201 19th Jun 2017 10:55am
