![]() | Home > Puma (Tdci) > Strange happening |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Started the Puma (65 plate 110 xsutility) this morning, noticed the Trip meter was showing Zero, was about 140 yesterday, it had reset to zero, everything else working ok, On reaching my destination mileage had increases to 8.0.
Did a re-key with ignition on back to zero. Locked the puma, carried on with my visit to friends, back to puma, ignition on, trip meter back to zero, radio codes lost. Turned off the ignition checked all of the Relays, both under the drivers seat and under steering column, everything ok, all seated properly. Started up drove home, trip meter at 8.4, parked up, left it for 2 hours, just checked still showing 8.4. Any ideas? NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 ![]() ![]() ![]() |
Interior lights working ? Only ask as when my trip Played up is was a fuse on interior lights
Interior Lighting and Radio operating as usual, need to re-code my favourite stations. NormanD WE191
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2541 ![]() ![]() ![]() |
Loosing the radio's pre sets indicates a loss of power from the battery. Defender 90XS SW
Battery terminal all tight, no movement on cables, therefore I need to start checking earth straps etc. NormanD WE191
