Home > Puma (Tdci) > Strange happening
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Strange happening
Started the Puma (65 plate 110 xsutility) this morning, noticed the Trip meter was showing Zero, was about 140 yesterday, it had reset to zero, everything else working ok, On reaching my destination mileage had increases to 8.0.
Did a re-key with ignition on back to zero. Locked the puma, carried on with my visit to friends, back to puma, ignition on, trip meter back to zero, radio codes lost.
Turned off the ignition checked all of the Relays, both under the drivers seat and under steering column, everything ok, all seated properly.
Started up drove home, trip meter at 8.4, parked up, left it for 2 hours, just checked still showing 8.4.
Any ideas? NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #631065 13th Jun 2017 2:14pm
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
Interior lights working ? Only ask as when my trip Played up is was a fuse on interior lights
Post #631078 13th Jun 2017 3:40pm
NormanD
Interior Lighting and Radio operating as usual, need to re-code my favourite stations. NormanD WE191
2015 110 XS Utility
Post #631100 13th Jun 2017 4:39pm
That suggests to me that you may have a loose battery connection. Resetting the radio and losing the trip reading will both normally happen if the battery is disconnected.
Post #631106 13th Jun 2017 4:48pm
discomog
Loosing the radio's pre sets indicates a loss of power from the battery. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #631113 13th Jun 2017 5:29pm
NormanD
Battery terminal all tight, no movement on cables, therefore I need to start checking earth straps etc. NormanD WE191
2015 110 XS Utility
Post #631117 13th Jun 2017 5:51pm
