![]() | Home > Maintenance & Modifications > ** Update = Sorted ** Spacers on and now wheel wobble. |
Lots of people use spacers so it can't be an insurmountable problem.
Check the obvious first; are the wheel nuts (and spacers nuts) tight? Try swapping the wheels front to back to see if that changes anything. If none of that resolves it then get the wheel balanced. Beyond the simple stuff, you're into swivel preloads, suspension bushes, etc. It is entirely possible that the spacers have just magnified wear that already existed but you need to eliminate the easy stuff before jumping to any conclusions. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Ooh, that was my 4000th post. How exciting. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Take the spacers out & try a run without them to see if you still have the wobble. If you had them fitted before the discs & pads were replaced & there was no wobble then I would suggest the fault lies with the discs or their fitting - do you get vibration & soft pedal when applying the brakes?? - these would suggest a warped or misaligned disc which could also be the cause of the wobble.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3854 ![]() ![]() |
Hello
All done at same time. Pedal feels completely normal..as do brakes. |
Update as I did remember
The garage guy did say my Drive flanges? (rear) had some play... but this would give a slight clunk in first and reverse? ![]() Thanks |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
Hi do you get the wobble in a straight line ? or when you turn to the left or the right ? Clayton.
1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
hello, i had this wheel wobble you describe when after i changed my springs to alive springs last week.
today i replaced the steering dampner and now it is all ok. in fact very more better. i sumise that the springs show me the pain of the steering damper that hide with the larger oem springs and changing it to fresh (bilstein) make the steering a very nice prospect now. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2021 ![]() ![]() ![]() |
I had the exact same as you, I was convinced it was the spacers, had the wheels balanced and all was good
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Hello
Will try again on the way home but around 45 mpg its like an American movie drive down a straight road and the wheels all over the place (if I lose grip on it..) Its back in on Wed, the Guy who fitted the brakes said he will take them off try it and then put them on... |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 ![]() ![]() ![]() |
It could just be that the spacers are exaggerating a wheel balancing problem that existed before but you didn't feel it? The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
More than likely the spacers have been fitted to the hub faces without the faces being cleaned up sufficiently.
The contact face of the original wheels (steel or alloy) is not the full face of the hubs. It is mostly an inner and outer circumference and patches around each wheel stud. The areas where the wheel do not contact get dirty and corrode. The spacers (or at least the good quality ones) have a fully machined surface on the back which makes contact with the whole hub face. If even a small patch of muck or corrosion is evident on the hub face the spacer does not mate flush and you end up with wheel wobble. The hubs should be wire brushed and thoroughly degreased before fitting the spacers. Steve 02' 110 TD5 Double Cab Rebuild Thread |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
I had a slightly wobble at 60-65 when spacers first fitted. Got wheels balanced (£8!) and were fine after.
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
^ Good point above hopefully can be sorted
![]() It's in Tomorrow What I don't understand is how balancing them would help in so much as they were ok before, unless as mentioned there was a slight wobble but not detectable? My first thought was balancing but then I didn't understand how this could help as they were ok before, Good point noted on cleaning the hib etc before fitting. Will tell the garage Will report back |
I just assumed in taking the wheels and refitting they must have knocked off a balancing weight but who knows?! James
