Home > Maintenance & Modifications > ** Update = Sorted ** Spacers on and now wheel wobble.
Page 1 of 4 1234>
Stacey007
Hello
Not used my car over the weekend and only drove back from Garage after new brake pads and discs under 40mph..
Drove it today and around 45 mph and 60 mph wobble...wobble wobble..
Is this the spacers? (hubcentric) it feels like when you lose a weight off a wheel?
Do I need to get the wheels balanced? seems odd it's only happened after spacers / Discs and pads fitted...
Shame as it does have a much better stance if I have to take them off... Big Cry
Thanks
Post #630699 12th Jun 2017 10:11am
Lots of people use spacers so it can't be an insurmountable problem.
Check the obvious first; are the wheel nuts (and spacers nuts) tight? Try swapping the wheels front to back to see if that changes anything. If none of that resolves it then get the wheel balanced.
Beyond the simple stuff, you're into swivel preloads, suspension bushes, etc. It is entirely possible that the spacers have just magnified wear that already existed but you need to eliminate the easy stuff before jumping to any conclusions. Darren
Post #630706 12th Jun 2017 10:19am
Ooh, that was my 4000th post. How exciting. Darren
Post #630707 12th Jun 2017 10:20am
VVS210
Take the spacers out & try a run without them to see if you still have the wobble. If you had them fitted before the discs & pads were replaced & there was no wobble then I would suggest the fault lies with the discs or their fitting - do you get vibration & soft pedal when applying the brakes?? - these would suggest a warped or misaligned disc which could also be the cause of the wobble.
Post #630708 12th Jun 2017 10:23am
Stacey007
Hello
All done at same time. Pedal feels completely normal..as do brakes.
Post #630711 12th Jun 2017 10:31am
Stacey007
Update as I did remember
The garage guy did say my Drive flanges? (rear) had some play... but this would give a slight clunk in first and reverse?
Thanks
Post #630713 12th Jun 2017 10:35am
L110CDL
Hi do you get the wobble in a straight line ? or when you turn to the left or the right ? Clayton.
Keeper.
Post #630920 12th Jun 2017 11:01pm
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
hello, i had this wheel wobble you describe when after i changed my springs to alive springs last week.
today i replaced the steering dampner and now it is all ok. in fact very more better.
i sumise that the springs show me the pain of the steering damper that hide with the larger oem springs and changing it to fresh (bilstein) make the steering a very nice prospect now.
Post #630926 12th Jun 2017 11:10pm
bear100
I had the exact same as you, I was convinced it was the spacers, had the wheels balanced and all was good Thumbs Up for the sake of a few quid have them checked 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #630936 12th Jun 2017 11:47pm
Stacey007
Hello
Will try again on the way home but around 45 mpg its like an American movie drive down a straight road and the wheels all over the place (if I lose grip on it..)
Its back in on Wed, the Guy who fitted the brakes said he will take them off try it and then put them on...
Post #630992 13th Jun 2017 9:45am
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
It could just be that the spacers are exaggerating a wheel balancing problem that existed before but you didn't feel it? The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years"
Solihull, 2015 - "If we paint the chassis.............................
Post #630996 13th Jun 2017 9:49am
rallysteve
More than likely the spacers have been fitted to the hub faces without the faces being cleaned up sufficiently.
The contact face of the original wheels (steel or alloy) is not the full face of the hubs. It is mostly an inner and outer circumference and patches around each wheel stud. The areas where the wheel do not contact get dirty and corrode.
The spacers (or at least the good quality ones) have a fully machined surface on the back which makes contact with the whole hub face. If even a small patch of muck or corrosion is evident on the hub face the spacer does not mate flush and you end up with wheel wobble.
The hubs should be wire brushed and thoroughly degreased before fitting the spacers.
Post #630997 13th Jun 2017 9:53am
JOW240725
I had a slightly wobble at 60-65 when spacers first fitted. Got wheels balanced (£8!) and were fine after. Thumbs Up James
Instagram @suffolk_rovers
Post #631017 13th Jun 2017 11:05am
Stacey007
^ Good point above hopefully can be sorted Smile
It's in Tomorrow
What I don't understand is how balancing them would help in so much as they were ok before, unless as mentioned there was a slight wobble but not detectable?
My first thought was balancing but then I didn't understand how this could help as they were ok before,
Good point noted on cleaning the hib etc before fitting. Will tell the garage
Will report back
Post #631072 13th Jun 2017 3:08pm
JOW240725
I just assumed in taking the wheels and refitting they must have knocked off a balancing weight but who knows?! James
Post #631075 13th Jun 2017 3:31pm
Page 1 of 4 1234>
