Home > Maintenance & Modifications > Vented brake discs
Stacey007
Vented brake discs
Hello
My 110 needs new pads and the discs are low.
While I get the pads changed I'm thinking fit some discs also.
Std Discs (rear) appear to be around £30 a pair.
Just been on John Craddock and vented, drilled and grooved would be £100 a pair. so £70 more. however I guess with my mileage should last a good few years,..
Is there any? benefit in getting these over ordinary ones? I;ve had high performance cars that have had these in the past but this is a truck... albeit a heavy one. I am thinking of getting the remap and oil cooler etc soon
https://www.johncraddockltd.co.uk/accessor...59807.html
Thanks
Post #629132 5th Jun 2017 3:26pm
Don't you need different callipers to go from standard to vented discs, as they're thicker? Darren
Post #629143 5th Jun 2017 3:54pm
Stacey007
^ No idea? but if anyone knows
Very Happy
Post #629148 5th Jun 2017 3:59pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Don't buy them!
They arrive in blue boxes, look good but that's it.
They do fit standard callipers.
I had 2 sets warp both under 5,000 miles
First set I thought just unlucky,
Second set just took the Censored to be honest..... Neutral 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #629153 5th Jun 2017 4:07pm
Stacey007
^ saves me £70 also Smile
Post #629154 5th Jun 2017 4:08pm
Retroanaconda
If your 110 is newer than 1994 or so it should have vented front discs as standard. Rears will be solid, and there will be no benefit to converting to vented.
Drilled/grooved are a waste of time in my opinion also. It's not like you're going to be driving it like a racing car.
Post #629170 5th Jun 2017 4:52pm
ericvv
Post #629177 5th Jun 2017 5:11pm
Stacey007
I can bob on it it but find the std brakes with std engine fine.
Will keep standard
Smile
Post #629252 5th Jun 2017 8:39pm
