![]() | Home > Maintenance & Modifications > Passenger door on puma not shutting fully (solved) |
hafman Member Since: 28 Mar 2017 Location: W Sussex Posts: 81 ![]() ![]() |
Have a look at this thread http://www.defender2.net/forum/topic54285.html
For me the problem seems to have been the (lack of a / worn away) nylon "sleeve" on the bit that screws in to the body - wrapping insulating tape around it has proved to be a very good temporary fix. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
If you're having to lift the door, check for wear in the hinges, as well as the plastic sleeve issue in the linked thread above. They're notorious for hinge-pin wear and may need replacing.
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3854 ![]() ![]() |
^ Thanks
I've read loads of thread on google, not sure what I need to adjust The locks all seem clean and striker looks newish (its a TDCi so quite new) I feel I need to be able to move the door up a little (tiny bit), but then It looks like it could be the rubbers round the door. I've also fitted stainless sills a while back and I don't think its been the same since so maybe I should take these off and see if that fix's it? Pain either way. Does anyone know what I need to adjust to make the doors stay open as both front ones don't now ![]() |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Hi
Tried the stainless sills on mine = Same problem ![]() Took them off ,used helicopter tape = Problem solved ![]() Good luck 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
