Home > Maintenance & Modifications > Passenger door on puma not shutting fully (solved)
Stacey007
hello
Annoying little problem, door on passenger side needs a good slam to shut or slightly lift the door and it shuts?
Also the passenger door used to 'hold open' on the catch but doesn't any more (drivers one never has been able to hold open on catch)...
So
1) What do I need to look at to make it shut? Can I adjust the door slightly?
2) how do I get the doors to stay open on the catch?
I searched and found the cleaning the lock threads which I will try but they are fairly clean
Thanks in advance
_________________________
I thought while starting to look at stuff the door has never shut right really since the stainless sills were fitted...
So I took it off, and it decided to chuck it down as I'm half under car Very Happy
Anyway, its off and the door shuts Very Happy
So the passenger can do without for now and I need new bolts to replace what I took out Smile
Post #623276 10th May 2017 10:46pm
hafman
Have a look at this thread http://www.defender2.net/forum/topic54285.html
For me the problem seems to have been the (lack of a / worn away) nylon "sleeve" on the bit that screws in to the body - wrapping insulating tape around it has proved to be a very good temporary fix.
Post #623325 11th May 2017 7:49am
If you're having to lift the door, check for wear in the hinges, as well as the plastic sleeve issue in the linked thread above. They're notorious for hinge-pin wear and may need replacing.
Post #623333 11th May 2017 8:34am
Stacey007
^ Thanks
I've read loads of thread on google, not sure what I need to adjust
The locks all seem clean and striker looks newish (its a TDCi so quite new)
I feel I need to be able to move the door up a little (tiny bit), but then It looks like it could be the rubbers round the door.
I've also fitted stainless sills a while back and I don't think its been the same since so maybe I should take these off and see if that fix's it?
Pain either way.
Does anyone know what I need to adjust to make the doors stay open as both front ones don't now Sad on the 'click'
Post #623350 11th May 2017 10:29am
Swine&Small
Hi
Tried the stainless sills on mine = Same problem Sad
Took them off ,used helicopter tape = Problem solved Very Happy
Good luck 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #623353 11th May 2017 10:42am
