Home > Maintenance & Modifications > Unwanted Engineering Challenge
Page 2 of 3 <123>
jst
heat Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #619867 27th Apr 2017 10:17am
Pilgrimmick wrote:
Is it an ex-military bumper?
No, it's a civilian copy and so lacks all of the unnecessary holes and came pre-drilled for the rubber end caps. I didn't realise that sorting the pin out would be such a pain though.
Further developments this evening. After having it sit in the freezer overnight, I took a punch and a lump hammer to it and did manage to move the broken bit slightly. Then broke my punch Rolling Eyes
I haven't got anything else to hand that is both hard enough to drive the bit out and only 2mm diameter and I can't find my blowtorch, which I haven't used for probably ten years, so I'm going to admit defeat and just buy another pin. Fortunately, they're not very expensive.
Thanks for all of the suggestions, though. Darren
Post #620023 27th Apr 2017 10:03pm
shaggydog
Have you tried Blanchard's?
https://www.pablanchard.co.uk/
I would be surprised if they don't have one! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #620146 28th Apr 2017 1:15pm
X4SKP
blackwolf wrote:
Several options:
1. Get a new pin, ideally of the right length!
2. Find someone with a spark erosion machine.
3. Using a pointed punch at the bottom of the 6mm hole, belt the bejasus out of it in the hope of bursting through and knocking the fragment out.
4. Heat the pin with oxy acetylene or oxy propane gear in the hope of expanding it enough to free off the fragment.
blackwolf has it right...i'd just change the order of attack...
4 Heat this up and be done with it
3 Then hit it when hot (if it doesn't fall out)
2 Will defiantly work (if you have time)
1 Just isn't a Defender Owners MO...
Good Luck... Thumbs Up SKIP
Post #620158 28th Apr 2017 2:17pm
gilarion
Have you tried using a Blacksmiths drill bit they are better quality then most jobber drill bits and as sharp as anything. Tool Station sells them at really cheap prices. I have drilled through hardened steel with one of these drill bits.
http://www.toolstation.com/search?searchst...36%2084868 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #620163 28th Apr 2017 2:40pm
Thanks for the idea but those drill bits are more expensive than a new pin (allowing for delivery) and are much bigger than the hole I'm trying to drill.
I had a look but their pins are about three times the cost and I'm not convinced they'd fit. As my bumper is a civilian copy, I suspect it's been made slightly differently which means that a slightly longer than normal pin is needed.
I've no reason to doubt Mr Blackwolfs suggestions. It's just become a trade off between buying more stuff to fix the problem and buying a new pin. I've gone for the latter, which should be with me tomorrow, as I need to use it over the weekend.
If necessary, I'll just use a pin at the length it comes, but with a bit more care with the drilling, I'm sure I can get it right second time around. I'll post pics Thumbs Up Darren
Post #620165 28th Apr 2017 3:15pm
Use a bigger drill for the pilot hole next time. 2mm is too small for a 1" deep pilot hole in a mild steel pin. I'd use a minimum of 4mm or 5mm.
Post #620196 28th Apr 2017 5:46pm
sako243
You need it shortened? Can that shortening happen at the 2mm hole end?
If so bring it to the next Sy4x4 meeting (or if you're passing Tongham) this weekend and I can chuck it on the lathe and put some carbide to it. That'll get through it.
A bit in hindsight but if it's a small drill bit you'll want the pillar drill to be on a fast setting otherwise you'll risk the bit biting and exactly this happening. I've got some pretty decent quality Presta drill bits and even managed to snap the 8mm bits because they're so damn sharp. Better off running fast and with coolant (not oil). Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #620216 28th Apr 2017 6:42pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Two ways to look at the problem Question
1) It's all great fun ...
I'm learning heaps about drills, metals, temperature, differential expansion (yes in theory the hole gets larger at the metal gets hotter SS expands at roughly 1.5 mm per m per 100 C, so I might expand the radius 1/10th mm if I can get it to 400+C) . I've even cleared out the shed and sorted it to look for a blow torch ...
2) My time is worth x quid per hour and is a very scarce resource.
Fixing the pin is costing n quid; getting a new one (n - heaps) quid, which I could spend on .. that nice green lane trip
Suggest solution 2 Rolling with laughter Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #620250 28th Apr 2017 8:44pm
Yeah, that's basically it. I'm very much a means to an end guy when it comes to this stuff Laughing
I realised my mistake the second it snapped Rolling Eyes I now know that trying to drill through 25mm of steel was just asking too much.
Thanks for the offer but the hole I was drilling is within the intended finished length as it's for the lynch pin. Darren
Post #620292 28th Apr 2017 11:33pm
ppad
Always liked the look of these central towing point, but in Oz I ended up with a tow ball one side bolted straight through to chassis and towing eye bolted to other chassis rail. Was never sure of the bumber strength.
This 'civilian' version, is it reinforced at the holes? If you recall your branch welding (B31.3 and branch reinforcement and all that) you need to be real careful of high stress points. The pin slides in the bumper, so can impose a point load of several Te at a single point on the bumper steel plate under shock load.
If not reinforced, I'd be tempted to take some thick and large washers and get them welded really neatly to upper and lower bumper steel and painted in to merge with bumper. Else, first time you pull a truck out of the mud you may, um, enlarge the sleeve in the bumper Whistle ? Sold the much modified 110 2.8, in Oz
Post #620344 29th Apr 2017 12:15pm
Problem solved Very Happy A slightly larger bit to start and a bit more care drilling out in stages and I've got a nice 6.5mm hole, bevelled on each side. Ten minutes with a hack saw lopped about an inch and a half off the end and then five minutes on the bench grinder saw the end shaped and polished.
I've also cut a rubber washer to sit under the top flange to stop it rattling against the bumper.
My failed first attempt is at the back:
The bumper is, I think, a standard one that's been beefed up to support the tow hitch. The centre section between the chassis mounts is now box section and the holes where the pin pass through have had very thick washers welded top and bottom. It's bloomin' heavy and I'm happy that it's substantial enough for its' intended purpose. I think it's the latter that's caused me such a problem though, as those washers make it thicker than the working length of a standard 4 inch pin.
Thanks for everyones' help and suggestions Thumbs Up Darren
Post #620435 29th Apr 2017 9:13pm
JAY BOY
Wales
Bow down Bow down
I wouldn't give up on the failed one. Drill 6.5mm from the good side find your blow torch. Knock the bit out.
Someone might steal the one on your car Whistle Whistle Rolling with laughter Rolling with laughter
Post #620440 29th Apr 2017 9:23pm
Heh, heh, rest assured it's not going to live on there permanently Laughing Darren
Post #620444 29th Apr 2017 9:42pm
zsd-puma
Post #621062 2nd May 2017 5:12pm
Page 2 of 3 <123>
