![]() | Home > Maintenance & Modifications > No Brake lights |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Try finding and cleaning the earth connection, it always seems to be earthing problems! Jeff
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
Either the switch or earthing as already suggested.
Probably earthing, try adding a temporary Earth and try it. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
The connector for the brake light switch is just behind the servo in the engine bay i think. Just unplug it and short it to ground (touch the two connectors together if it's a plastic two connector switch) if the brake lights work then you know it's the switch, if not it's a bad earth to the tail lights.
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Check for other light failures on the rear i.e. reverse, side lights and indicators. You may have to lay underneath the near side just behind the battery box and check and the main earth to the chassis it has a habit of corroding. It is on the inside of the longitudinal chassis member. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
JamesF Member Since: 10 Nov 2016 Location: Hitchin Posts: 71 ![]() ![]() ![]() |
Thanks for all the advice. I did manage to sort it. Was a broken wire.
It was in one of tose places that scrape the knuckles and bring on a bout of swearing lol. |
