Home > Maintenance & Modifications > No Brake lights
JamesF
United Kingdom 1989 Defender 90 2.5 TD HT Baltic Blue
No Brake lights
Hi all
It seems neither of my brakelights are working.
The fuse seems to be ok and the bulbs work. Is it possible the brake light switch has gone?
Trouble is I am not sure where it is located?
I think it maybe in the pedal box but that looks inaccesable to me:(
I have a 1989 defender
Thanks
Post #616719 14th Apr 2017 8:45am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Try finding and cleaning the earth connection, it always seems to be earthing problems! Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #616767 14th Apr 2017 11:40am
Either the switch or earthing as already suggested.
Probably earthing, try adding a temporary Earth and try it. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #616773 14th Apr 2017 12:49pm
zsd-puma
The connector for the brake light switch is just behind the servo in the engine bay i think. Just unplug it and short it to ground (touch the two connectors together if it's a plastic two connector switch) if the brake lights work then you know it's the switch, if not it's a bad earth to the tail lights.
Post #616778 14th Apr 2017 1:47pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Check for other light failures on the rear i.e. reverse, side lights and indicators. You may have to lay underneath the near side just behind the battery box and check and the main earth to the chassis it has a habit of corroding. It is on the inside of the longitudinal chassis member. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #616851 14th Apr 2017 8:42pm
JamesF
Thanks for all the advice. I did manage to sort it. Was a broken wire.
It was in one of tose places that scrape the knuckles and bring on a bout of swearing lol.
Post #617162 16th Apr 2017 8:43am
