![]() | Home > Maintenance & Modifications > Variable voltage wiring? |
proloForêt Member Since: 16 Mar 2017 Location: Montereau Posts: 248 ![]() ![]() ![]() |
Hello,
Today I am installing a new view behind camera and need to attach to the reversing light power. In the manual for the camera it says to me that I should use a relay if the reversing light is wired with a "variable voltage wire" or if not just wire direct to the light positive wire. I have no idea what this means or how I can test this. Do anyone know this answer which I hope is "no, the reversing light on a Defender does not use a variable voltage wiring"! It is 2008 90 SW. Many thanks Léo |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17886 ![]() ![]() ![]() |
No, the reversing light on a Defender does not use a variable voltage wiring.
Ah monsieur blackwolf, once again prove you to be the best man of the world! Merci.
Perhaps also you know this: For sure the red wire from the light is the positive power. I connect that, but the black wire from the light is just going on a route to a ground point? So instead of looking to bolt the ground negative wire from the camera to the body someplace, I can "splice" to this black wire in the light?
My knowledge of vehicle electric systems needs improvement! |
