Home > Maintenance & Modifications > Variable voltage wiring?
proloForêt
France 2008 Defender 90 Puma 2.4 XS CSW Java Black
Hello,
Today I am installing a new view behind camera and need to attach to the reversing light power.
In the manual for the camera it says to me that I should use a relay if the reversing light is wired with a "variable voltage wire" or if not just wire direct to the light positive wire. I have no idea what this means or how I can test this.
Do anyone know this answer which I hope is "no, the reversing light on a Defender does not use a variable voltage wiring"!
It is 2008 90 SW.
Many thanks
Léo
Post #615332 8th Apr 2017 1:28pm
No, the reversing light on a Defender does not use a variable voltage wiring. Thumbs Up
Post #615336 8th Apr 2017 1:45pm
proloForêt
Ah monsieur blackwolf, once again prove you to be the best man of the world! Merci.
Mr. Green
Post #615343 8th Apr 2017 2:11pm
proloForêt
Perhaps also you know this: For sure the red wire from the light is the positive power. I connect that, but the black wire from the light is just going on a route to a ground point? So instead of looking to bolt the ground negative wire from the camera to the body someplace, I can "splice" to this black wire in the light?
My knowledge of vehicle electric systems needs improvement!
Post #615344 8th Apr 2017 2:14pm
A plain black wire on a Landrover (provided it was there when it left the factory) will always be a ground wire, so yes, that should be ok.
Post #615350 8th Apr 2017 3:40pm
