![]() | Home > Maintenance & Modifications > Transfer box |
Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487 ![]() ![]() ![]() |
Morning Everyone
Can I fit a Disco 2 t/box into the 90? If so will it alter the speedo etc? Cheers Life is one big adventure, that's why we have the vehicle for the journey. |
yes and yes.
although the D2 TB may not hve the centre diff lock. you can get a kit from ashcrofts with Q gears |
most D2 boxes don't have the diff lock internals fitted, they have the high and low, not te diff lock. Take them both part nd make a good one out of the two ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6046 ![]() ![]() |
Ashcroft don't do quiet gears, and they are .............
The gearing does make a good change for the better, but I would not bother if I new how much work it involved to get one decent box from a supplier. 4 trans boxes later and 4 Gboxes later I am getting there Make sure you keep the CDL, BUT you will loose the PULL from the lights. I did miss this in the dunes, but not on the drive to them Andy |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Hello,
I bought my td5 with what I was told Disco gearing, after a little research I am happy it has it. I still have the Defender transfer box after checking the numbers but the rpm at 60 mph is equivalent to a disco. I guess it has just the gears then, and yes they are noisy, I though I had a bearing going but it must just be these gears. Right where I cruise at 60 mph it drives me nuts. wwwiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii I have top quality oil too.. |
Cheers Guys, I'll keep an eye out for one. Life is one big adventure, that's why we have the vehicle for the journey.
