Home > Maintenance & Modifications > Transfer box
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
Transfer box
Morning Everyone
Can I fit a Disco 2 t/box into the 90? If so will it alter the speedo etc?
Cheers Life is one big adventure, that's why we have the vehicle for the journey.
Post #56202 2nd Feb 2011 12:43pm
T1G UP
yes and yes.
although the D2 TB may not hve the centre diff lock.
you can get a kit from ashcrofts with Q gears
Post #56210 2nd Feb 2011 1:34pm
T1G UP wrote:
yes and yes.
although the D2 TB may not have the centre diff lock.
There's no reason why you shouldn't keep the CDL from the 90 TB on the D2 TB.
Post #56228 2nd Feb 2011 4:14pm
T1G UP
blackwolf wrote:
T1G UP wrote:
yes and yes.
most D2 boxes don't have the diff lock internals fitted, they have the high and low, not te diff lock. Take them both part nd make a good one out of the two Thumbs Up
Post #56268 2nd Feb 2011 7:03pm
landy andy
Ashcroft don't do quiet gears, and they are .............
The gearing does make a good change for the better, but I would not bother if I new how much work it involved to get one decent box from a supplier.
4 trans boxes later and 4 Gboxes later I am getting there
Make sure you keep the CDL, BUT you will loose the PULL from the lights. I did miss this in the dunes, but not on the drive to them
Andy
Post #56295 2nd Feb 2011 8:55pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello,
I bought my td5 with what I was told Disco gearing, after a little research I am happy it has it. I still have the Defender transfer box after checking the numbers but the rpm at 60 mph is equivalent to a disco.
I guess it has just the gears then, and yes they are noisy, I though I had a bearing going but it must just be these gears. Right where I cruise at 60 mph it drives me nuts. wwwiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
I have top quality oil too..
Post #56317 2nd Feb 2011 10:03pm
Mr Baldylocks
Cheers Guys, I'll keep an eye out for one. Life is one big adventure, that's why we have the vehicle for the journey.
Post #57037 6th Feb 2011 12:42am
