Home > Maintenance & Modifications > ACF - 50
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
ACF - 50
I'm going to be getting under the chassis this weekend to start the lovely job of wirebrushing.
Normally I just spray old oil underneath from old engine changes, however I was looking at the Opie oil site and came across this stuff: http://www.opieoils.co.uk/p-114485-acf-50-...itres.aspx
Sounds very convincing... any thoughts before a drop nearly a ton on 4 litres of this gloop?
Post #610209 17th Mar 2017 11:45pm
Go for Dinitrol underbody and internals wax for just a few quid more.
ACF 50 is better used under cappings and on visible fixings etc as it is clear and safe on paints.
In fact, I definitely wouldn't use ACF 50 on the chassis, main reason is that it isn't exactly tough.
If you go for underbody work I would recommend stonechip underarches too, it has a good effect.
Obviously you have to stonechip first.
There is lots of info on here regarding this if you search on here regarding 'underbody protection' or 'Dinitrol' etc.
Yes, there are other options out there but me - I like Dinitrol, and I know it works!
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #610212 17th Mar 2017 11:59pm
zsd-puma
Someone will pipe in about Buzweld too in a bit, it seems they have good marketing, and product placement.
But my recommendation would be Dinitrol
Post #610216 18th Mar 2017 12:05am
mse
FCX is better than ACF 50 but neither really for this job Mike
Post #610220 18th Mar 2017 12:27am
Kit
Glad I asked now, i'll take a look at the Dinitrol stuff
Post #610223 18th Mar 2017 12:36am
zsd-puma
The thing with Dinitrol is they do a range of products, dependent on where they're used. So there are more runny penetrating waxes for spraying into cavities, and more solid products to resist wash off in wheel arches and the outsides of a chassis.
They also do heat resistant products for use in engine bays.
Post #610227 18th Mar 2017 1:08am
MGCarr
United Kingdom 1997 Defender 90 300 Tdi PU Rioja Red
Bilt-Hamber is also well worth a look as they do a range of rust converters, cavity waxes, underbody waxes and high zinc primers in aerosol or bulk. Rustbusters is another option they do fe-123 which is a rust converter which seems to get good reviews in the classic car magazines, they also supply Dinitrol bulk waxes in more sensible container sizes than other suppliers.
Post #610230 18th Mar 2017 2:37am
