![]() | Home > Off Topic > Best paint for a caravan roof ? |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello Daisy90
First suggestion is to use what's on there currently...or a near equivalent If it's Painted Aluminum, then it may be either: Cellulose (old type before this was discontinued (banned)) or it may be a Stove Enamel (higher cost and durable finish applied to higher end Vans) So for now... use a conventional Car Paint or an Enamel, both can be sprayed (and both can be applied by a roller... ![]() Preparation If any bare aluminium is exposed when keying the surface (Wet and Dry) use an etch primer (ACID Etch 8 Halfords will do) Application Spaying is best, and even if you go down the 'Roller Route', you need almost the same conditions, weather, masking off etc. If you Roller then consider using a Varnish Roller (very fine sponge roller) and the results can be very good Thin the paint so that it's just a bit thicker than if you were to put this through a gun. (I did our two garage doors with Hammerite, smooth matt textured finish, and you just can't tell that it was applied with a 5 inch varnish roller) There is a chance that your caravan roof is fiberglass (like ours) in which case there are gell coat type refinishing products or you can go down the Car Paint Route... ![]() Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
Going by the state mine gets into over the winter, a good coating of marine anti-fouling paint would be best.
![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3673 ![]() ![]() ![]() |
vinyl wrap? try 3m online DEFENDER 90 TDCI XS,
/\...good shout...
![]() ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
