![]() | Home > Puma (Tdci) > Whats this weird blue grease |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Sure it's grease and not something like blue Hylomar sealant?
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
well if it was a sealant it has no sealing capabilities - isnt the measure seal a room temp flex at high temp Mike
Hylomar stays like a sticky goo. Without knowing roughly where it came from it's a guessing game.
And thats the problem i dont know Mike |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
have you hit something in the road ? not like a blue rabbitt ! i mean like something off a contractors truck or from some road workings ? is it joint stuff for pipes ? sorry dont know the technical terminology..........
Its feasable i supose ? well it is for me anyway. DEFENDER XS CSW 08 TONGA GREEN |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Or a Smurf?? |
Damm !
Forgot about them pesky smurfs ! DEFENDER XS CSW 08 TONGA GREEN |
Sorry....... couldn't help myself Chalky!
![]() I've had a look under my 110 and can't see any blue grease or sealer, most of the sealers that I can see is black. Have you checked the rubber boots on your steering joints/ball joints mse? One of them could have split or detached itself, and who knows what sort of grease they are filled with?? Tim |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 ![]() ![]() |
Smurfs.......I Like it
![]() I would suspect it's an anarobic sealant, which seals when there is lack of air, but remains liquid in the presence of air, or even Blue hermetite, which is semi hard. I expect it's round the diff flange. Regards Steve |
Daniel TD5 Member Since: 22 Jul 2007 Location: london Posts: 97 ![]() ![]() ![]() |
my one how as bright yellow sealant on the gearbox after it was replaced
they don,t seem to need gaskets any more dan |
Makes sense - the excess (there was a lot) does wonders to lubricate the gate
