Home > Technical > Femco drain plug.
Femco drain plug.
I have one on the td5, does anybody know which thread i need for the 2.4 puma ? QRZ 2e0vpf
Post #597350 29th Jan 2017 5:54pm
gilarion
I am sure the size you need is this Drainplug M16 X 1.5 T10/37L - Standard Series
Have a word with John at Femco he will advise if this is the correct size
http://www.drainplug.co.uk/standard.html
contact
http://www.drainplug.co.uk/contact.html
or phone 01455 202626
there is a good thread about sizes here
http://www.defender2.net/forum/topic29173....drain+plug For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #597353 29th Jan 2017 6:09pm
Thanks very much, will do Thumbs Up QRZ 2e0vpf
Post #597354 29th Jan 2017 6:10pm
MartinK
I hope you are well. I bought one for my 2.4 a while back. I emailed FEMCO and the mail they sent back:
Quote:
The drain plug you require is a DP1039 Femco Plug M14x1.5 T11.5 at £25.50 and a drain tube DP1023 Drain tube, 600mm at £10.75. Carriage will be £2.50. With VAT the total will be £46.50. If this is acceptable we will send a paypal invoice which you can pay online. When we get the funds we will ship 1st Class post.
Been perfect Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #597557 30th Jan 2017 8:21am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I fitted one to my Td5 but it is deathly slow. Is this a 'feature' of them, or is mines not opening far enough? Apart from that I am very happy with it.
Post #597559 30th Jan 2017 8:24am
It's usually worth warming the engine a bit first Thumbs Up QRZ 2e0vpf
Post #597562 30th Jan 2017 8:54am
Thanks Martin K, I'll get one right now, cheers Cool QRZ 2e0vpf
Post #597564 30th Jan 2017 8:55am
MartinK
It is slower than just removing the std drain plug, but not too bad. Benefit is no tools, and super clean to do - just a 27mm for the oil filter.
Assuming oil is thin and hot it's OK. Saves you scalding your hand on the hot oil Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #597567 30th Jan 2017 9:33am
Litch
They are excellent, had one on my 300TDi for about 12-years now.
Yes, they do flow better if the oil is warm.
Took the one off my wife's Freelander 1 TD4 when we sold it the other day, available for anyone who is interested. ONE LIFE, GET IT!
Post #597764 30th Jan 2017 9:20pm
Toxic_Avenger
Australia 2012 Defender 90 Puma 2.2 SW Orkney Grey
Can confirm M14x1.5 thread.
I went with a Stahlbus though.
Post #597974 31st Jan 2017 11:12am
dgardel
Italy
contact
PUMA TDCI need the M14 X 1.5 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #598118 31st Jan 2017 8:51pm
Correct. I emailed them as suggested and just clicked on the link, I just checked my order confirmation and it is
DP1039 m14x1.5 T11.5 Thumbs Up QRZ 2e0vpf
Post #598130 31st Jan 2017 9:32pm
gilarion
Sorry for the wrong advice copied from another D2 thread, that's why I advised to phone Femco to check Thumbs Up
Taken from the web site
Details
Eliminate messy oil changes forever!
The Difflock supplied drain plug allows you to carefully control the speed and flow of oil from the sump when servicing your vehicle. No more oil spills on hands, driveways, axles, anti-roll bars, exhausts, chassis, or anything else that might be in the way.
Once fitted, it eliminates the risk of cross-threading or damaging the sump threads especially on aluminium sumps. The Difflock supplied drain plug contains multiple internal O-rings to ensure a complete oil-tight seal, and is patented worldwide.
You will need to buy a universal drainer hose with your first drain plug, but if you are buying more than 1 drain plug, you do not need additional drainer hoses since 1 drainer hose will fit them all.
Suitable for:
Defender TD5
Discovery TD5
Post #598252 1st Feb 2017 1:23pm
Cool just turned up.
thanks chaps.
 QRZ 2e0vpf
Post #598820 3rd Feb 2017 2:35pm
gilarion
On the container that the drain plug comes in you will find a torque setting make sure you torque to that value, it’s important to do so. Thumbs Up For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #598844 3rd Feb 2017 5:05pm
