![]() | Home > Technical > Femco drain plug. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I have one on the td5, does anybody know which thread i need for the 2.4 puma ? QRZ 2e0vpf
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
I am sure the size you need is this Drainplug M16 X 1.5 T10/37L - Standard Series
Have a word with John at Femco he will advise if this is the correct size http://www.drainplug.co.uk/standard.html contact http://www.drainplug.co.uk/contact.html or phone 01455 202626 there is a good thread about sizes here http://www.defender2.net/forum/topic29173....drain+plug For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 Last edited by gilarion on 29th Jan 2017 6:11pm. Edited 1 time in total |
Thanks very much, will do
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
I hope you are well. I bought one for my 2.4 a while back. I emailed FEMCO and the mail they sent back:
Been perfect ![]() |
It's usually worth warming the engine a bit first
Thanks Martin K, I'll get one right now, cheers
It is slower than just removing the std drain plug, but not too bad. Benefit is no tools, and super clean to do - just a 27mm for the oil filter. Assuming oil is thin and hot it's OK. Saves you scalding your hand on the hot oil ![]() |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
They are excellent, had one on my 300TDi for about 12-years now.
Yes, they do flow better if the oil is warm. Took the one off my wife's Freelander 1 TD4 when we sold it the other day, available for anyone who is interested. ONE LIFE, GET IT! |
Toxic_Avenger Member Since: 07 Jan 2017 Location: New South Wales Posts: 6 ![]() ![]() ![]() |
Can confirm M14x1.5 thread.
I went with a Stahlbus though. |
PUMA TDCI need the M14 X 1.5 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Correct. I emailed them as suggested and just clicked on the link, I just checked my order confirmation and it is
DP1039 m14x1.5 T11.5 ![]() |
Sorry for the wrong advice copied from another D2 thread, that's why I advised to phone Femco to check
![]() Taken from the web site Details Drainplug M16 X 1.5 T10/37L - Standard Series Eliminate messy oil changes forever! The Difflock supplied drain plug allows you to carefully control the speed and flow of oil from the sump when servicing your vehicle. No more oil spills on hands, driveways, axles, anti-roll bars, exhausts, chassis, or anything else that might be in the way. Once fitted, it eliminates the risk of cross-threading or damaging the sump threads especially on aluminium sumps. The Difflock supplied drain plug contains multiple internal O-rings to ensure a complete oil-tight seal, and is patented worldwide. You will need to buy a universal drainer hose with your first drain plug, but if you are buying more than 1 drain plug, you do not need additional drainer hoses since 1 drainer hose will fit them all. Suitable for: Defender TD5 Discovery TD5 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
![]() thanks chaps. ![]() Click image to enlarge QRZ 2e0vpf |
On the container that the drain plug comes in you will find a torque setting make sure you torque to that value, it’s important to do so.
![]() http://www.youtube.com/user/conwy1 |
