Home > Technical > Diagnostic kit - Laymans guide please
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Hi folks,
I've been reading a number of the threads on the Nanocom/Hawkeye/Scangauge/BBS etc etc and whilst I'm probably setting myself up here for a bucket load of mickey taking (which is fine Very Happy ), As a complete layman when it comes to this I have a few simple 'general' questions.. (I've searched for a general thread but couldn't find one - so apologies if I've missed it )
Bit of background first, I've got a Td5 engined 2005 110. Owned for about a month. Before that had an old V8 Disco. I have a VERY VERY basic mechanical and electrical knowledge but when it comes to the ECU - I'm completely lost Sad . So my intention is to use a decent local indy specialist for works but I do like to be able to speak with an element of knowledge when dealing with them so that at least, I've done some of the fault finding for them... hopefully saves a few quid.
Here's the questions....
1) Are these bits of kit simply diagnostic? I.e - they read and can clear fault codes. I get that bit. Do they actually enable you to 'tweak' the ECU in any way, i.e to improve MPG, torque, drivability etc etc.
Maybe some do and some don't - can you tell me which do and which don't - at the mo, I get the impression that BBS seem to do stuff that's 'tweakable' but Scangauge for example is exactly that - a gauge.
2) If I were to buy one and lets assume I cannot or chose not to tweak the ECU, what value to me is there in being able to clear fault codes? Other than the dealer/indy garage doesn't do it and charge me for it. Am I right in thinking that If I decipher the codes, I can work out which are serious and need attention and which ones are insignificant and can be simply cleared.
3) Once say a minor fault is logged in the ECU, does this adversley affect the running of the engine? So is there a point at which the ECU triggers some kind of 'safe mode' for the engine as it's built up a collection of fault codes.
4) Most people talk about the diagnostic kit on these forums for the PUMA's. Is it fair to say that all the makes mentioned above would work on Td5's or at least there is a Td5 variant ?
5) Presumably, they are just plug and play? I've seen what looks like the diagnostic connector on mine just under the cubby box on the near side.
6) Based on what you can see from my lack of knowledge, and accept this is a difficult question to answer, do you think I'd get value for money in having one of these bits of kit , if so, which one is the best alrounder or shall I just give up and accept I'm a numpty and pay a nice man to sort it ? Very Happy
7) Why the bl**dy hell didn't I buy a 200tdi !
Rather embarrassed so go easy on me please Embarassed Embarassed Jon - 110 td5 [sold]. Currently Defenderless.
Post #53965 19th Jan 2011 7:13pm
Lorryman100
I'll answer what I can, these opinions are just mine so please remember that Whistle
1. I have a scangauge and a nanocom, the scangauge lives on the dash permanently connected to the OBDII port in the fusebox ( I have a Puma). This allows me to view things like mpg, air/coolant temps etc. It also shows and allows reseting of faultcodes, though not all of them. It will however allow you to see what illuminated the MIL light and allow you to choose whether or not you call out LR assist or just book the vehicle into the dealer yourself. Now a point to note is that if you clear the fault it will disappear from the ECU memory and when LR plug in there machine it will not show as you have basically deleted it by reseting it. I find the scangauge a handy little tool for everyday use as it gives you additional gauges which are standard in most cars.
The nanocom is a different type of Diagnostic equipment as it allows you into these four modules:
Puma/Td5 engine: Fault reading and clearing, Injector coding, Live feed from engine systems ie: EGR,MAF,Engine speed, engine torque, coolant temp ( cylinder head), engine load etc,etc.
Instrument cluster: Fault reading and clearing, live data on instrument settings
10AS alarm module: Inputs function to allow you too see all the parameters monitored ie: drivers door, drivers key, bonnet, volumetric sensors. The ability to code new fobs, to disable the immobiliser etc.
WABCO ABS: Fault reading and clearing, inputs and outputs of ABS sensors, Allows power and modulator bleeds and allows testing of each wheel sensor, brake and pump relay voltages etc.
There is more to these modules than I have listed but you should get the idea. The fact it allows you basically to turn things on and off which aids you in fault finding is invaluable IMHO.
2. Yes. Dgardel has them uploaded HERE
3. Only certain faults trigger the MIL light or the MIL and limp home mode. The ECU will keep a record of all other faults until cleared.
4. Scangauge doesn't work on Td5, nanocom has a Td5 variant.
5. Yes, once the unit is plugged into the OBDII socket it boots up.
6. I looked at both the Nanocom and the BBS MSV, for me for the money the Nanocom in my opinion won the day for what modules were included in the price.
7. What you should really be asking yourself is why you didn't buy a PUMA!!!!!!!!!!!!!!!!!!!!!!!!
Nothing to be embarrassed about, that's why forums are here, whether you take the advice given or not. Thumbs Up
HTH Brian.
Post #54038 19th Jan 2011 11:07pm
party monkey
Thankyou Brian, I surprised myself that I actually understood all of what you were saying (well.... kind of Wink )
At the mo, sounds to me like the Nanocom probably offers best all round package. Can I just follow up on a couple of your answers (sorry)
1) Would the Nanocom allow me to re-program the ecu (as in the same way as say a tuning company) to try to achieve better MPG?
2) Dgardel's fault code list is excellent but it looks like its for the Puma engine. Are the fault codes the same for the Td5 ?
7) Very Happy - looked at a PUMA but deciding factor in the end was the budget and also the 9 seats in the Td5's. Yes, 7 sometimes is not enough.
Thanks again for your help.
Jon Jon - 110 td5 [sold]. Currently Defenderless.
Post #54070 20th Jan 2011 10:03am
Lorryman100
jon,
1. Not sure? However there are members on here with TD5's who have nanocoms.
2. I saw you had a TD5 but as this is predominantly a Puma forum decided to post dgardel's list for new members benefit. However a quick search on google brought up sites with TD5 fault codes Thumbs Up
7. Was pulling your leg Whistle
HTH Brian.
Post #54071 20th Jan 2011 10:18am
Lorryman100
Meant to say that if you get a nanocom you dont need a list of faultcodes as the nanocom gives you the fault code and description Thumbs Up
Also check out my gallery for pictures on the nanocom.
Post #54074 20th Jan 2011 10:24am
party monkey
Looks like it's a Nanocom in due course. Just need to convince the missus she wants one of them for valentines day Very Happy
Worked at Christmas, when got a dog guard and for her recent birthday she got 4 new BFG's and a liberal dosing of Waxoyl. My was I popular Shocked Shocked
Thankyou very much again Brian for all your help.
Cheers,
Post #54076 20th Jan 2011 10:34am
Merlin
Hi Lorryman100, how do you keep your Scangauge connected? I've tried driving with the Nanocom plugged in but the cable hangs down a bit. Also you have to remove the cover.
Merlin
Post #54164 20th Jan 2011 8:00pm
mse
Merlin
The port easily pops out if you wanted Mike
Post #54175 20th Jan 2011 8:17pm
Lorryman100
Merlin,
the scangauge OBDII socket is smaller in bulk and the cable exits at 90 degrees which allows me to undo the screw holding the OBD socket in the fusebox and pushing it into the rear of the fusebox with the scangauge plugged in, this allows the cover to be closed with only a slight bulge. Also the cable is fed down behind the dash so no cables are visible once the cover is closed Thumbs Up
Post #54262 21st Jan 2011 12:54am
