![]() | Home > Technical > Diagnostic kit - Laymans guide please |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I'll answer what I can, these opinions are just mine so please remember that ![]() 1. I have a scangauge and a nanocom, the scangauge lives on the dash permanently connected to the OBDII port in the fusebox ( I have a Puma). This allows me to view things like mpg, air/coolant temps etc. It also shows and allows reseting of faultcodes, though not all of them. It will however allow you to see what illuminated the MIL light and allow you to choose whether or not you call out LR assist or just book the vehicle into the dealer yourself. Now a point to note is that if you clear the fault it will disappear from the ECU memory and when LR plug in there machine it will not show as you have basically deleted it by reseting it. I find the scangauge a handy little tool for everyday use as it gives you additional gauges which are standard in most cars. The nanocom is a different type of Diagnostic equipment as it allows you into these four modules: Puma/Td5 engine: Fault reading and clearing, Injector coding, Live feed from engine systems ie: EGR,MAF,Engine speed, engine torque, coolant temp ( cylinder head), engine load etc,etc. Instrument cluster: Fault reading and clearing, live data on instrument settings 10AS alarm module: Inputs function to allow you too see all the parameters monitored ie: drivers door, drivers key, bonnet, volumetric sensors. The ability to code new fobs, to disable the immobiliser etc. WABCO ABS: Fault reading and clearing, inputs and outputs of ABS sensors, Allows power and modulator bleeds and allows testing of each wheel sensor, brake and pump relay voltages etc. There is more to these modules than I have listed but you should get the idea. The fact it allows you basically to turn things on and off which aids you in fault finding is invaluable IMHO. 2. Yes. Dgardel has them uploaded HERE 3. Only certain faults trigger the MIL light or the MIL and limp home mode. The ECU will keep a record of all other faults until cleared. 4. Scangauge doesn't work on Td5, nanocom has a Td5 variant. 5. Yes, once the unit is plugged into the OBDII socket it boots up. 6. I looked at both the Nanocom and the BBS MSV, for me for the money the Nanocom in my opinion won the day for what modules were included in the price. 7. What you should really be asking yourself is why you didn't buy a PUMA!!!!!!!!!!!!!!!!!!!!!!!! Nothing to be embarrassed about, that's why forums are here, whether you take the advice given or not. ![]() HTH Brian. |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Thankyou Brian, I surprised myself that I actually understood all of what you were saying (well.... kind of
![]() At the mo, sounds to me like the Nanocom probably offers best all round package. Can I just follow up on a couple of your answers (sorry) 1) Would the Nanocom allow me to re-program the ecu (as in the same way as say a tuning company) to try to achieve better MPG? 2) Dgardel's fault code list is excellent but it looks like its for the Puma engine. Are the fault codes the same for the Td5 ? 7) ![]() Thanks again for your help. Cheers Jon Jon - 110 td5 [sold]. Currently Defenderless. |
jon,
1. Not sure? However there are members on here with TD5's who have nanocoms. 2. I saw you had a TD5 but as this is predominantly a Puma forum decided to post dgardel's list for new members benefit. However a quick search on google brought up sites with TD5 fault codes ![]() 7. Was pulling your leg ![]() HTH Brian. |
Meant to say that if you get a nanocom you dont need a list of faultcodes as the nanocom gives you the fault code and description
![]() Also check out my gallery for pictures on the nanocom. |
Looks like it's a Nanocom in due course. Just need to convince the missus she wants one of them for valentines day
![]() Worked at Christmas, when got a dog guard and for her recent birthday she got 4 new BFG's and a liberal dosing of Waxoyl. My was I popular ![]() ![]() Thankyou very much again Brian for all your help. Cheers, Jon Jon - 110 td5 [sold]. Currently Defenderless. |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Hi Lorryman100, how do you keep your Scangauge connected? I've tried driving with the Nanocom plugged in but the cable hangs down a bit. Also you have to remove the cover.
Merlin |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5107 ![]() ![]() ![]() |
The port easily pops out if you wanted Mike |
Merlin,
the scangauge OBDII socket is smaller in bulk and the cable exits at 90 degrees which allows me to undo the screw holding the OBD socket in the fusebox and pushing it into the rear of the fusebox with the scangauge plugged in, this allows the cover to be closed with only a slight bulge. Also the cable is fed down behind the dash so no cables are visible once the cover is closed ![]() ![]() Click image to enlarge |
