![]() | Home > Technical > 200tdi won't start |
Are you getting 12v to the starter? If so give it a little tap, could just be a sticky solenoid. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Nothing silly like Isolator switch or Immobiliser is it? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter ![]() |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1903 ![]() ![]() |
No idea Marsh to be honest, but will try tapping regardless.
Ha ShaggyDog, just the sort of daft thing I would overlook but it has neither. |
And so I thought I would just try the key again after 2 days of deadness and guess what, it started! Kind of wish it hadn't coz now I guess it is something intermittent . . . . . ..
![]() Ok well if it isn't throwing over when it fails it must be something in the starter motor circuit so best start there. I am assuming it is still doing the Glow Plugs? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
It is still doing the glow plugs
Ok so when you turn the key to position 3 nothing happens?
Lights don't dim, no clicking from starter motor? That would to me indicate that the starter is not drawing power I would start small with Starter Relay, key switch, check wiring where possible. If not, then start looking along at new starter motor solenoid, new starter motor. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
and nip up (check all battery cables, earths etc etc. ) the grand thing is being a tdi it should be easy enough to fault
![]() my youtube channel |
