Home > Technical > 200tdi won't start
CarMan
200tdi won't start
Put it away 2 weeks ago and now it just won't start Big Cry
Battery is new but was low so have charged.
When I turn the key no click, nothing, but in addition to the oil and battery lights the 'Brake' and 'Temp' lights come on while the key is turned.
No idea what to check?
About a year ago I fixed the dash binnacle and after that it would intermittently not start or cut out and that was it dead but with dash lights, until I unscrewed the clocks and put them back again! Though I don't recall the extra lights coming on. I never fixed it, it just went away and has been perfect since.
Is there a loose connection that might cause this or faulty ignition switch perhaps?
Anyway, this time clocks out and back and still nothing! Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #587683 26th Dec 2016 2:42pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Are you getting 12v to the starter? If so give it a little tap, could just be a sticky solenoid. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #587689 26th Dec 2016 3:04pm
shaggydog
Nothing silly like Isolator switch or Immobiliser is it? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #587692 26th Dec 2016 3:08pm
CarMan
No idea Marsh to be honest, but will try tapping regardless.
Ha ShaggyDog, just the sort of daft thing I would overlook but it has neither.
Post #587706 26th Dec 2016 3:30pm
CarMan
And so I thought I would just try the key again after 2 days of deadness and guess what, it started! Kind of wish it hadn't coz now I guess it is something intermittent . . . . . ..
Post #587713 26th Dec 2016 3:49pm
shaggydog
Censored ! yes an intermittent fault is more of a problem than a consistent one as they are far harder to diagnose.
Ok well if it isn't throwing over when it fails it must be something in the starter motor circuit so best start there.
I am assuming it is still doing the Glow Plugs? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #587743 26th Dec 2016 5:14pm
CarMan
It is still doing the glow plugs
Post #587744 26th Dec 2016 5:16pm
shaggydog
Ok so when you turn the key to position 3 nothing happens?
Lights don't dim, no clicking from starter motor? That would to me indicate that the starter is not drawing power
I would start small with Starter Relay, key switch, check wiring where possible. If not, then start looking along at new starter motor solenoid, new starter motor. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #587750 26th Dec 2016 5:50pm
g-mack
and nip up (check all battery cables, earths etc etc. ) the grand thing is being a tdi it should be easy enough to fault Thumbs Up ! My 109 thread
my youtube channel
Post #587801 26th Dec 2016 7:59pm
