Home > Puma (Tdci) > Coolant confusion, PUMA uses OAT
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Been looking into coolants since I topped up my Triumph with Castrol M/C coolant "grand prix" then found out I should have used a Hybrid OAT (HD4X)
Must be the cold cold weather - as all my vehicles seem to have low fluids
Mk4 Hilux only has standard old style blue Ethylene (should really replace this good for 2 years)so no problem just bought some Car Plan Bluestar
Puma hand book states Texaco XLC which on reading into this coolant the manufacturer does say "it is compatible with most other coolants based on ethylene glycol",the Texaco (Havoline) is an OAT coolant and as such I have purchased for top up TRIPLE QX (RED) ANTIFREEZE which is also OAT
Anyone have further thoughts on this ?
Post #579220 20th Nov 2016 6:36pm
dorsetsmith
I use non land rover OAT antifreezes that mix ok with land rover spec antifreezes
Post #579223 20th Nov 2016 6:52pm
This is what I run and is suitable for a Puma:
http://www.opieoils.co.uk/p-903-motul-inug...o-use.aspx ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #579249 20th Nov 2016 7:49pm
agentmulder
Kuwait
I cant recall the thread, but I'm 90% sure that 'Havoline Xtended Life Anti-Freeze/Coolant (XLC) Concentrate' is the same product as the recommended Texaco XLC.
Located in Caltex stations locally, unsure what you've got over that way Thumbs Up Solved the bowel problem, working on the consonants...
Post #579798 23rd Nov 2016 6:54am
Iktank
Thanks for that I feel happier I have suitable coolant.
I did some checking and the Texaco and Havoline XLC is the same thing
Post #579903 23rd Nov 2016 7:15pm
