![]() | Home > Puma (Tdci) > Coolant confusion, PUMA uses OAT |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 239 ![]() ![]() ![]() |
Been looking into coolants since I topped up my Triumph with Castrol M/C coolant "grand prix" then found out I should have used a Hybrid OAT (HD4X)
Must be the cold cold weather - as all my vehicles seem to have low fluids Mk4 Hilux only has standard old style blue Ethylene (should really replace this good for 2 years)so no problem just bought some Car Plan Bluestar Puma hand book states Texaco XLC which on reading into this coolant the manufacturer does say "it is compatible with most other coolants based on ethylene glycol",the Texaco (Havoline) is an OAT coolant and as such I have purchased for top up TRIPLE QX (RED) ANTIFREEZE which is also OAT Anyone have further thoughts on this ? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
This is what I run and is suitable for a Puma:
http://www.opieoils.co.uk/p-903-motul-inug...o-use.aspx ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
I cant recall the thread, but I'm 90% sure that 'Havoline Xtended Life Anti-Freeze/Coolant (XLC) Concentrate' is the same product as the recommended Texaco XLC.
Located in Caltex stations locally, unsure what you've got over that way ![]() |
Thanks for that I feel happier I have suitable coolant.
I did some checking and the Texaco and Havoline XLC is the same thing |
